Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya2022 bug ? (deformerSets)
3 REPLIES 3
animation3d
1080 Views, 3 Replies
Seems maya2022 no longer creates a deformerSet-node, when creating new deformers.
However this link (under Legacy deformer set editing)
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Maya-Cha...
mentions that tools such as DeformerSet Editor and EditMemeberShip Tool should still work.
But this seems not to be the case.
To test, just create a sphere, and add a cluster, and open the DeformerSetEditor.
Labels (1)
  • bug
3 REPLIES 3
zewt
in reply to: animation3d
You can still use the deformer set editor to edit deformer sets, but your deformers won't have any deformer sets to edit unless you disable component tags.  It's under Preferences > Animation > Rigging > Use component tags for deformation component subsets.
shilov.kirill
in reply to: zewt
Thank you so much, zewt!
jperezlPN46T
in reply to: zewt
I try that and still doesn't work. Any  suggestion?
