Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya2020 MacOS Catalina 10.15.2 application crashes
19 REPLIES 19
Message 1 of 20
ge53
3463 Views, 19 Replies
I cannot even open Maya2020 MacOS Catalina 10.15.2 / the application crashes, same with Maya 2019--this is a clean install. Also tried loading application through terminal, same results.
Error message says:
"Fatal error. Attempting to save in  /var/folders/n9/ynnxhj2128z6rs_bs1_4td480000gn/T/username.20200207.1242.ma"
I am attaching 2 apple logs, one from the terminal.
I am an educator and really need to use this--Any ideas? help, suggestions MUCH appreciated
19 REPLIES 19
Message 2 of 20
warnold1
in reply to: ge53
I haven't seen this startup crash before.
have you setup your Security and Privacy settings for Accessibility,  Full Disk Access and Files and Folders to allow Maya access to them ?    in the System Preferences
Wayne Arnold
Developer
Message 3 of 20
ge53
in reply to: warnold1
thank you--unfortunately this did not work, i have the same error message.
here is another log, this one from the terminal:
/Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/Maya
objc[1605]: Class QMacAutoReleasePoolTracker is implemented in both /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/libQt5Core.5.12.5.dylib (0x10f947200) and /Users/<user
>/Library/Python/2.7/lib/python/site-packages/PySide2/Qt/lib/QtCore.framework/Versions/5/QtCore (0x1282906b0). One of the two will be used. Which one is undefined.
objc[1605]: Class QT_ROOT_LEVEL_POOL__THESE_OBJECTS_WILL_BE_RELEASED_WHEN_QAPP_GOES_OUT_OF_SCOPE is implemented in both /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/libQt5Core.5.12.5.dylib (0x10f947278) and /Users/<user>/Library/Python/2.7/lib/python/site-packages/PySide2/Qt/lib/QtCore.framework/Versions/5/QtCore (0x128290728). One of the two will be used. Which one is undefined.
objc[1605]: Class KeyValueObserver is implemented in both /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/libQt5Core.5.12.5.dylib (0x10f9472a0) and /Users/geraldineerman/Library/Python/2.7/lib/python/site-packages/PySide2/Qt/lib/QtCore.framework/Versions/5/QtCore (0x128290750). One of the two will be used. Which one is undefined.
objc[1605]: Class RunLoopModeTracker is implemented in both /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/libQt5Core.5.12.5.dylib (0x10f9472f0) and /Users/geraldineerman/Library/Python/2.7/lib/python/site-packages/PySide2/Qt/lib/QtCore.framework/Versions/5/QtCore (0x1282907a0). One of the two will be used. Which one is undefined.
QPixmap: Must construct a QGuiApplication before a QPixmap
Stack trace:
4 libsystem_kernel.dylib 0x00007fff6d43e7fa __pthread_kill + 10
5 libsystem_c.dylib 0x00007fff6d3c5a1c abort + 120
6 QtCore 0x0000000127d5d5a9 QMessageLogger::debug(char const*, ...) const + 969
7 QtCore 0x0000000127d5ecf4 QMessageLogger::fatal(char const*, ...) const + 202
8 QtGui 0x00000001299819cf QPixmap::QPixmap() + 303
9 QtGui 0x000000012998200f QPixmap::QPixmap(QPixmap const&) + 47
10 QtGui 0x0000000129983a20 QPixmap::scaled(QSize const&, Qt::AspectRatioMode, Qt::TransformationMode) const + 432
11 QtGui.so 0x0000000129f90c85 Sbk_QPixmapFunc_scaled(_object*, _object*, _object*) + 1765
12 Python 0x000000010e937ebe PyEval_EvalFrameEx + 30206
13 Python 0x000000010e9305b2 PyEval_EvalCodeEx + 1538
14 Python 0x000000010e93cde5 fast_function + 117
15 Python 0x000000010e937ab4 PyEval_EvalFrameEx + 29172
16 Python 0x000000010e93ce82 fast_function + 274
17 Python 0x000000010e937ab4 PyEval_EvalFrameEx + 29172
18 Python 0x000000010e9305b2 PyEval_EvalCodeEx + 1538
19 Python 0x000000010e93cde5 fast_function + 117
20 Python 0x000000010e937ab4 PyEval_EvalFrameEx + 29172
21 Python 0x000000010e9305b2 PyEval_EvalCodeEx + 1538
22 Python 0x000000010e92ffa6 PyEval_EvalCode + 54
23 Python 0x000000010e9509e1 PyImport_ExecCodeModuleEx + 241
24 Python 0x000000010e953bcf load_source_module + 1055
25 Python 0x000000010e954832 import_submodule + 274
26 Python 0x000000010e9542c8 load_next + 280
27 Python 0x000000010e95208e PyImport_ImportModuleLevel + 1230
28 Python 0x000000010e92b767 builtin___import__ + 135
29 Python 0x000000010e8947e3 PyObject_Call + 99
30 Python 0x000000010e935e8d PyEval_EvalFrameEx + 21965
31 Python 0x000000010e9305b2 PyEval_EvalCodeEx + 1538
32 Python 0x000000010e92ffa6 PyEval_EvalCode + 54
33 Python 0x000000010e9509e1 PyImport_ExecCodeModuleEx + 241
34 Python 0x000000010e953bcf load_source_module + 1055
35 Python 0x000000010e954832 import_submodule + 274
36 Python 0x000000010e9542c8 load_next + 280
37 Python 0x000000010e95208e PyImport_ImportModuleLevel + 1230
38 Python 0x000000010e92b767 builtin___import__ + 135
39 Python 0x000000010e8947e3 PyObject_Call + 99
40 Python 0x000000010e935e8d PyEval_EvalFrameEx + 21965
41 Python 0x000000010e9305b2 PyEval_EvalCodeEx + 1538
42 Python 0x000000010e92ffa6 PyEval_EvalCode + 54
43 Python 0x000000010e9509e1 PyImport_ExecCodeModuleEx + 241
1zsh: segmentation fault /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/Maya
Last login: Fri Feb 7 15:03:42 on console
*geraldineerman@geraldimansimac ~ %
/Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/Mayaobjc[1605]:
(0x10f947200) and
undefined.objc[1605]: Class
(0x10f947278) and
undefined.objc[1605]: Class KeyValueObserver is implemented in both
(0x10f9472a0) and
undefined.objc[1605]: Class RunLoopModeTracker is implemented in both
(0x10f9472f0) and
(0x1282907a0). One of the two will be used. Which one is undefined.QPixmap:
Must construct a QGuiApplication before a QPixmapStack trace: 4
5 libsystem_c.dylib 0x00007fff6d3c5a1c abort + 120 6
QMessageLogger::debug(char const*, ...) const + 969 7 QtCore
const + 202 8 QtGui 0x00000001299819cf
QPixmap::QPixmap() + 303 9 QtGui
0x000000012998200f QPixmap::QPixmap(QPixmap const&) + 47 10 QtGui
Qt::AspectRatioMode, Qt::TransformationMode) const + 432 11 QtGui.so
_object*, _object*) + 1765 12 Python
0x000000010e937ebe PyEval_EvalFrameEx + 30206 13 Python
0x000000010e9305b2 PyEval_EvalCodeEx + 1538 14 Python
0x000000010e93cde5 fast_function + 117 15 Python
274 17 Python 0x000000010e937ab4
PyEval_EvalFrameEx + 29172 18 Python
0x000000010e9305b2 PyEval_EvalCodeEx + 1538 19 Python
0x000000010e93cde5 fast_function + 117 20 Python
0x000000010e937ab4 PyEval_EvalFrameEx + 29172 21 Python
0x000000010e9305b2 PyEval_EvalCodeEx + 1538 22
54 23 Python 0x000000010e9509e1
PyImport_ExecCodeModuleEx + 241 24 Python
0x000000010e953bcf load_source_module + 1055 25 Python
0x000000010e954832 import_submodule + 274 26 Python
0x000000010e9542c8 load_next + 280 27 Python
0x000000010e95208e PyImport_ImportModuleLevel + 1230 28
+ 135 29 Python 0x000000010e8947e3
PyObject_Call + 99 30 Python
0x000000010e935e8d PyEval_EvalFrameEx + 21965 31 Python
0x000000010e9305b2 PyEval_EvalCodeEx + 1538 32 Python
0x000000010e92ffa6 PyEval_EvalCode + 54 33 Python
241 34 Python 0x000000010e953bcf
load_source_module + 1055 35 Python
0x000000010e954832 import_submodule + 274 36 Python
0x000000010e9542c8 load_next + 280 37 Python
0x000000010e95208e PyImport_ImportModuleLevel + 1230 38 Python
0x000000010e92b767 builtin___import__ + 135 39
PyEval_EvalFrameEx + 21965 41 Python
0x000000010e9305b2 PyEval_EvalCodeEx + 1538 42 Python
0x000000010e92ffa6 PyEval_EvalCode + 54 43 Python
0x000000010e9509e1 PyImport_ExecCodeModuleEx + 2411zsh:
segmentation fault
/Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/Mayageraldineerman@geraldimansimac
Message 4 of 20
warnold1
in reply to: ge53
From the trace, looks like there is a conflict between Maya’s embedded python and a local copy in your directory
do you have any environment variables set when running maya or in a Maya.env file ?
MAYA_*
PYTHONHOME
PYTHONPATH
From a terminal window can see environment variables with the command:
env
Wayne Arnold
Developer
Message 5 of 20
ge53
thanks for your continued help--unfortunately i'm not well-versed on terminal commands--i am attaching  my info after entering env terminal command--no idea how to proceed from here?
Message 6 of 20
warnold1
in reply to: ge53
The list of EVs does not explain why your local copy of PySide2 is being referenced
Maya has its own embedded versions of both Qt and PySide2
the stack trace starts from some PySide2 usage, but is not from the version within the Maya framework
do you have additional plugins being loaded?
what version of PySide2 do you have locally
Wayne Arnold
Developer
Message 7 of 20
ge53
thanks for your reply
i am not very clear about terminal commands--i will attach below the info
received form the env command --i don't know how to proceed from here, any
help welcome!:
*Last login: Sun Feb 9 12:56:25 on consolegeraldineerman@geraldimansimac ~
% cd /Applications/Autodesk/Maya2020geraldineerman@geraldimansimac Maya2020
envTERM_PROGRAM_VERSION=433TMPDIR=/var/folders/n9/ynnxhj2128z6rs_bs1_4td480000gn/T/XPC_FLAGS=0x0LANG=en_US.UTF-8TERM_PROGRAM=Apple_TerminalXPC_SERVICE_NAME=0DISPLAY=/private/tmp/com.apple.launchd.JM6EXkH6PV/org.macosforge.xquartz:0TERM_SESSION_ID=6D952CAB-56CD-4E0D-9AFA-06DA9B90BB77SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.AUZTtfNJiy/ListenersTERM=xterm-256colorSHELL=/bin/zshHOME=/Users/geraldineermanLOGNAME=geraldineermanUSER=geraldineermanPATH=/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/share/dotnet:/opt/X11/bin:~/.dotnet/tools:/Library/Frameworks/Mono.framework/Versions/Current/CommandsSHLVL=1PWD=/Applications/Autodesk/Maya2020OLDPWD=/Users/geraldineerman_=/usr/bin/envgeraldineerman@geraldimansimac
Maya2020 % *
Message 8 of 20
ge53
Thank you again! I am unclear about/how Python works.
Perhaps te conflict is related to using XCode + usdz convertor tools, as i
think i remember installing some Python tools?
But I am unclear what to do now?
thanks again..
Message 9 of 20
warnold1
in reply to: ge53
As a test you could rename the directory:
to hide it.   this would break whatever is expecting to see/use PySide2, but should remove it from Maya's view.   By renaming, its possible to return the name as it was before
in a Terminal window:
cd /Users/geraldineerman/Library/Python/2.7/lib/python/site-packages
mv PySide2 PySide2-hide
to rename back to the origin
mv PySide2-hide PySide2
Wayne Arnold
Developer
Message 10 of 20
ge53
Wow-that seems to work--hopefully not gonna affect further use(s)
Python...Thank you so much, G.E.
Message 11 of 20
jackiezxt
Hi, @warnold1 thanks, I got the PySide2 problem too. That causes maya2020 on Catalina crashed when opening it. But after I `pip uninstall PySide2`, or rename the folder to PySide2-hide, maya2020 still tells me that it needs shiboken-based type when opening it. But I need PySide2 on some other stuff, how can I fix it, please?
This window just jumped up and disappeared, the maya2020 auto closed again and give no other error information.
Message 12 of 20
warnold1
in reply to: jackiezxt
Are you running Maya or MayaLT ?
if Maya LT may be a different issue
the change above was hiding the user's local PySide2 directory.
what version (path) of PySide2 did you remove/hide ?    not Maya's  correct.
If you removed Maya's copy of PySide2, then you  will most likely start to see PySide2 errors.
what was your original problem ?  the output of the message of the missing MTsetToggleMenuItem
Wayne Arnold
Developer
Message 13 of 20
WindXu
Did you uninstall or rename PySide inside Maya? What the original errors are before you removed PySide?
Do you have PYTHONPATH or PYTHONHOME set before starting Maya?
Message 14 of 20
jackiezxt
no, I didn't remove Maya's PySide, and I'm not using Maya LT, it still there under the path
-- /Applications/Autodesk/maya2020/Maya.app/Contents/bin/pyside2-rcc
I just followed the instructions on Github and "pip install" pyside2 on my mac in order to build pixar_usd, nothing else I did.
After built pixar_usd,  maya crashed. So I find the post here, to uninstall the pyside2 that I just installed, and the error just jumped out like that.
Message 15 of 20
jason.fielder
Suffered from this too. I had to uninstall PySide2 and shiboken
pip uninstall shiboken2
Then Maya started successfully.
Message 16 of 20
WindXu
in reply to: jason.fielder
Hi Jason,
Are you also on Catalina? Does this happen with old OSX versions?
Message 17 of 20
jason.fielder
in reply to: WindXu
Yes, I'm on Catalina. Not sure about older versions of macOS
Message 18 of 20
lucericr
in reply to: ge53
I know this solution maybe a little too technical, but it can help someone else that needs to keep Pyside installed.
You can prevent Maya from loading the Pyside you "pip installed" on your Mac by setting the environment variable  PYTHONUSERBASE to another folder before launching Maya at the command line.  That variable is used to find your user python folder. For example, you could type in the terminal "export PYTHONUSERBASE=~/MyPythonFolder", and then  launch Maya at the command (with something like "open /Application/Autodesk/Maya2020/Maya.app") in the terminal
The environment variable prevents python from loading the packages in ~/Library/Python
Setting the variable only just before launching Maya allows continuing to use Python normally outside of Maya and only make a special case for Maya.
The only issue is, of course, that it then not load any of the other packages you have installed. However, it would be possible to install these packages in that MyPythonFolder That's what the variable is for: redirect your use folder to somewhere else.
Message 19 of 20
ge53
yes, thank you for this solution/it works--
Message 20 of 20
lucericr
in reply to: ge53
Crash with user-installed Pyside was fixed on Maya 2020 update 3
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Maya-Rel...
