Maya2017sp4 - premature 'Syntax errors' in Script Editor
When 'Show Toolitip Help' is checked in Script Editor - Maya floods user with 'syntax error like' messages while typing:
or this:
IMHO instead - maya just should not show tooltip if there is nothing that it can show tooltip for.
BTW: Maya's script editor is probably the only one that deletes code when executing 😉
More descriptive tooltips for 2 execute buttons might be 'execute' and 'execute and delete'
mspeer
Hi!
I can not reproduce the problem.
Please try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Works the same on 2 different machines. Probably 'object path completition' needs to be checked too
