Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya xGen Warning: XGen(Tip): OpenCL is disabled
12 REPLIES 12
Message 1 of 13
nabilfx
12857 Views, 12 Replies
Warning: XGen(Tip):  OpenCL is disabled. See output window for more details
cant see the brush
Hi @nabilfx your title 'Maya error Xgen help' was edited for clarity by @sean.heasley
Tags (1)
12 REPLIES 12
Message 2 of 13
sean.heasley
in reply to: nabilfx
Hi @nabilfx
This issue is usually caused by your GPU drivers being out of date. If you can either update or rollback your driver to our supported version that should solve your issue!
Here you can find the list of our supported GPU's and their drivers!
Here is how you can check your GTX 980 driver version number:
  1. Open your Start Menu and type Device Manager
  2. Under the 'Display Adapters' tab right click your gpu and select 'Properties'
  3. Under the Details tab you will see Driver Version.
Please let me know if this helps solve your issue, if not I'll be happy to keep working with you!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 13
nabilfx
in reply to: sean.heasley
Heres the driver
NVIDIA GeForce GTX 750 Ti
im using Windows 10
Message 4 of 13
sean.heasley
Hi @nabilfx
While we don't officially support the gt 750 ti I had a user using the gtx 980 and the supported driver for that is 382.33.
That said, I'd recommend (as do Nvidia) uninstalling the old drivers and then install the 382.33 driver
Nvidia have an article with steps on how to do so and can be found here.
Once you have installed the drivers, check the version number by repeating the steps from my previous post to make sure you are on 382.33!
I hope this helps resolve your issue but let me know if you need any more assistance!
Message 5 of 13
nabilfx
it Works thank you!
Message 6 of 13
eesso7016
Hi
I have a problem
 "" Warning: XGen(Tip): OpenCL is disabled. See output window for more details. maya ""
I have GTX 1050
Message 7 of 13
abmourya6790
NVIDIA GeForce GT 710
Message 8 of 13
go to  install NVIDIA path and copy 2 files :
C:\Program Files\NVIDIA Corporation\OpenCL
copy : OpenCL.dll ,  OpenCL64.dll
then paste these two file to maya path in bin maya folder:
for example in  :   c:..................\Maya2018\bin
Tags (2)
Message 9 of 13
Having this issue as well did the steps to try and fix still not working my gpu is supported.
Message 10 of 13
infoAVYNA
Hi I have the same problem, my GPU is NVIDIA Quadro RTX 4000, Driver Version is 27.21.14.6192, I followed your advice and updated the driver, but still doesn't work, OpenCL is disabled.
Message 11 of 13
pokabi3UT6T
Hi! I have the same problem. When I open maya it says "OpenCL evaluator failed to find OpenCL device with vendor NVIDIA Corporation".
My version of maya is 2019.3.1 and my graphic card is a nvidia geforce gtx 1660ti
Message 12 of 13
theonejibo
My solution: prefereces/ Display / then I switch on the viewport 2.0 from openGl to Directx11 and that did the trick to me
Message 13 of 13
sputknick
Sean, This OPEN CL problem appears to still be a mess. I've run into it again and again over the past couple years. And it makes working with XGen a nightmare as at least half the tools are no longer supported. And nothing online seems to give good clear answers on this. Further your pdf for Maya 2020 is old (it says August 2020 but appears older) as it doesn't show any support for 3070s etc. Right now I'm running into this issue again and it appears intractable - and sadly seems to pop up out of nowhere on machines that were once working fine. I'm currently using a Razer 15inch laptop, NVidia 3070s with Maya 2020.4 with NVIDIA driver number 465.89. As you likely know it is difficult switching around between NVIDIA drivers at the wrong ones will crash Windows 10 without warning or explanation. Currently running Windows Version 21H2 and OS Build 19044.1766.  Please advise.
