Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya Xgen - Guide Check -- How do I fix Zero Length Guides?
0 REPLIES 0
Message 1 of 1
413 Views, 0 Replies
Hi there! First time posting here! Trying to work through some issues with Xgen Core.
I'm not sure how this happened but it seems as if my guides are reading Errors with Guide Check (in Utilities)  In some earlyier iterations, My guides appeared to be working fine and Guide Check gave off no warnings. Now, when I run Guide Check it appears that every single guide in my scene reads as "Zero Length Guides".  From here, my only two options are to select or to delete. I don't want to do that to either. Anyone know the best course of action to fix Zero Length Guides?
For a solution, I've tried converting my Guides to Curves, then re-converting the Curves to Guides. Unfortunately, it didn't seem to fix the issue.
Can I just ignore the check for Zero Length Guides?
Thanks so much!
0 REPLIES 0
