Maya Xgen description
Message 1 of 1
Hello! I started using Maya 2019 at University courses, so I'm not very good on it and maybe my question is out of place.
The matter is that on my laptop Xgen seems to work unproperly from the first step. After I create a new description "Splines, Randomly across the surface , using attributes controlled by expressions" on selected object appear really big splines in diametr and there are no rose "dots" on polygons, which should be, as I saw them in all videos and also had on University's laptop. I reinstalled Maya in versions 2020 and 2019, but Xgen is always the same.
Also I'm facing program crashes when work with nHair and make the curves dymanic.
What should it be, maybe it's problem with computer system?
Thank you!
Replies (0)
