When I select one shell of a UV and unfold all the other UVs that arent selected unfold with it. I dont know what to do. First time unwrapping stuff.
Hi @Anonymous
The Unfold tool will unfold the entire model regardless of what you have selected.
The Layout tool however will only work on the selected shells.
If you can provide some screenshots I can help you with any other questions you may have.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Hi @Anonymous
Hmm ok.
I'll mark this as solved for now but if the issue occurs again please update me here!
All the best,
Sean Heasley
