Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
maya-usd v0.1.0 Vertex Normals problem
2 REPLIES 2
g2m.agent
1221 Views, 2 Replies
I used a new plugin (maya-usd) to export and then import the model, the vertex normals changed, why?
maya 2020 + maya-usd v0.1.0maya 2020 + maya-usd v0.1.0
Maya 2020
autodesk maya-usd v0.1.0 https://github.com/Autodesk/maya-usd/releases/tag/v0.1.0
Tags (1)
2 REPLIES 2
Set the export setting to "None (Polygonal Mesh)" instead of "Catmull-Clark".
https://linktr.ee/cg_oglu
ziethriel
in reply to: g2m.agent
I just want to add a note for future googlers. I had this same issue, but the problem was I had a single face with zero geometry area in the scene. Run a cleanup on your mesh for that issue. It did not show up as non-manifold or lamina, I had to search for zero geometry area.
This took me more than 10 hours to find, hopefully I can save you some frustration.
