Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya to zbrush export scaling issue
2 REPLIES 2
himinglaeva47
2011 Views, 2 Replies
Im having crazy scale issues between maya and zbrush.  If I directly import to maya from zbrush the scale is in meters even though i have units set to cm. So, I went and used scale master to import in cm and its correct. Then If I model anything in maya and export it back to zbrush its in meters again. So I export using Fbx as mm and its correct. What is going on?
I appreciate any help resolving the issue
2 REPLIES 2
Just use the subtoolMaster with multiapped and it should import in the right size.
Thats a Zbrush issue not maya. OBJ files do not care about cm or meter.
https://linktr.ee/cg_oglu
Thank you
