Been having issues for a few weeks now when I open certain scenes. I've been losing the textures, having data loss/file read errors and crashing several times a day. Looks like there's a few errors here. See below. Let me know if you need the scene file. It is quite large.
file -f -new;
// Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
// Warning: file: C:\Users\alex.bannerman\OneDrive - Ward and Burke\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\alex.bannerman\OneDrive - Ward and Burke\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\alex.bannerman\OneDrive - Ward and Burke\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\alex.bannerman\OneDrive - Ward and Burke\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// AbcExport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
# pymel.core : Updating pymel with pre-loaded plugins: mayaHIK, invertShape, GamePipeline, CloudImportExport, curveWarp, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, ATFPlugin, hairPhysicalShader, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, VectorRender, gameFbxExporter, OpenEXRLoader, lookdevKit, Unfold3D, Type, modelingToolkit, deformerEvaluator, GPUBuiltInDeformer, fbxmaya
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already. //
import arnold
// Successfully imported python module 'arnold'
import mtoa
// Successfully imported python module 'mtoa'
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
Maya 2018 importing module pymel 1.0.10 (C:\Program Files\Autodesk\Maya2018\Python\lib\site-packages\pymel\__init__.pyc)
# Error: Register failed for arnoldAOVChildSelector #
// Successfully registered renderer 'arnold'
// Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: Loading plug-in "mtoa" has resulted in changes to the scene that may need to be saved. //
// AbcImport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
updateRendererUI;
updateRendererUI;
closeNodeEditorEd hyperShadePrimaryNodeEditor;
file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "C:/Users/alex.bannerman/OneDrive - Ward and Burke/Documents/Visual Safe Systems of Work/Projects/14 Caisson Sinking/04 Autodesk Maya Files/scenes/6m ID Shutter_v028.mb";addRecentFile("C:/Users/alex.bannerman/OneDrive - Ward and Burke/Documents/Visual Safe Systems of Work/Projects/14 Caisson Sinking/04 Autodesk Maya Files/scenes/6m ID Shutter_v028.mb", "mayaBinary");
requires "OpenEXRLoader" "2012";
requires -nodeType "aiOptions" -nodeType "aiAOVDriver" -nodeType "aiAOVFilter" -nodeType "aiSkyDomeLight" -nodeType "aiStandardSurface" "mtoa" "2.1.0.1";
requires "stereoCamera" "10.0";
updateRenderOverride;
requires "rpmaya" "2.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rpmaya", was not found on MAYA_PLUG_IN_PATH. #
requires "xfrog" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog", was not found on MAYA_PLUG_IN_PATH. #
// Warning: line 0: swatches file depend node not found, icon discarded: a //
// Warning: line 0: swatches file depend node not found, icon discarded: bentonitePipe //
// Warning: line 0: swatches file depend node not found, icon discarded: plywoodEdge //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_eight //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_thirteen //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_six //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_two //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_three //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_eleven //
// Warning: line 0: swatches file depend node not found, icon discarded: i //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_four //
// Warning: line 0: swatches file depend node not found, icon discarded: b_spec //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_eighteen //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_fourteen //
// Warning: line 0: swatches file depend node not found, icon discarded: bm_a //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_five //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_nineteen //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_seventeen //
// Warning: line 0: swatches file depend node not found, icon discarded: waterTpiece //
// Warning: line 0: swatches file depend node not found, icon discarded: bm_e //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_one //
// Warning: line 0: swatches file depend node not found, icon discarded: d //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_twelve //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_seven //
// Warning: line 0: swatches file depend node not found, icon discarded: surfaceShader2 //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_ten //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_nine //
// Warning: line 0: swatches file depend node not found, icon discarded: b //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_fifteen //
// Warning: line 0: swatches file depend node not found, icon discarded: foamSpots //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_sixteen //
// Warning: line 0: swatches file depend node not found, icon discarded: rebar1 //
// Warning: line 0: swatches file depend node not found, icon discarded: waterPipe //
// Warning: line 0: swatches file depend node not found, icon discarded: c //
// Warning: line 0: swatches file depend node not found, icon discarded: piles_twenty //
// Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
