Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya Shuts Down When Using UV Editor
1 REPLY 1
talhahelvaci
291 Views, 1 Reply
Hi ,
 My Maya 2019 shuts down when I use "UV Editor" I don't know what is problem, I tried repair and reinstall before share this forum .
 After this issue usually I see "Fatal Error" and when I open my scene (.ma) file again, Maya freeze again and again in 5 mins. Often I don't see any error warning/notification
Thanks in advance
I wish you healthy days
Here's Crash Log
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0xFFFFFFFF
Fault address: 3A322575 in C:\Windows\SYSTEM32\ntdll.dll
0001:00011575 Logical offset (see .map file for location)
Call stack:
Module: C:\Program Files\Autodesk\Maya2019\bin\Foundation.dll (-exported-)
Decl: public: virtual __cdecl Tarray::~Tarray(void) __ptr64
Location: Foundation.dllTsingleIndexedComponent::~TsingleIndexedComponent + 30 bytes
Decl: protected: virtual __cdecl TsingleIndexedComponent::~TsingleIndexedComponent(void) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\PolyEngine.dll (-exported-)
Location: PolyEngine.dllTmidFaceComponent::~TmidFaceComponent + 109 bytes
Decl: protected: virtual __cdecl TmidFaceComponent::~TmidFaceComponent(void) __ptr64
Location: PolyEngine.dllTpolyGrpDesc::setComponent + 1F bytes
Decl: public: void __cdecl TpolyGrpDesc::setComponent(class TmidComponent const * __ptr64) __ptr64
Location: PolyEngine.dllTpolyGeom::setObjectGroupComponent + 11A bytes
Decl: public: void __cdecl TpolyGeom::setObjectGroupComponent(unsigned int,class TmidComponent const * __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\Poly.dll (-exported-)
Location: Poly.dllTdnAttrTdnpolyColorPerVertex::operator= + 649 bytes
Decl: public: struct TdnAttrTdnpolyColorPerVertex & __ptr64 __cdecl TdnAttrTdnpolyColorPerVertex::operator=(struct TdnAttrTdnpolyColorPerVertex const & __ptr64) __ptr64
Location: Poly.dllTmeshShape::makeComponentsActive + 154 bytes
Decl: public: virtual void __cdecl TmeshShape::makeComponentsActive(class TcomponentList const & __ptr64,bool,bool) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\DataModel.dll (-exported-)
Location: DataModel.dllTdagSelectionItem::setActive + FC bytes
Decl: public: virtual void __cdecl TdagSelectionItem::setActive(bool,bool) __ptr64
Decl: public: bool __cdecl Tmodel::makeActive(class TselectionItem * __ptr64,enum TlistAdjustment) __ptr64
Decl: public: bool __cdecl Tmodel::makeActive(class TselectionList const & __ptr64,enum TlistAdjustment) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\Shared.dll (-exported-)
Decl: public: virtual void __cdecl TselectCmd::finalize(void) __ptr64
Decl: public: static void __cdecl TselectCmd::select(class TselectionList const & __ptr64,enum TlistAdjustment,bool,enum TselectCmd::TdisplayCommand)
Module: C:\Program Files\Autodesk\Maya2019\bin\ModelUISlice.dll (-exported-)
Location: ModelUISlice.dllTtexContext::marquee + 1A0 bytes
Decl: public: virtual int __cdecl TtexContext::marquee(class TportRect & __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\ImageUI.dll (-exported-)
Location: ImageUI.dllTiiViewSelectContext_generic<TrgbaPoint32>::doRelease + 7E bytes
Decl: public: virtual int __cdecl TiiViewSelectContext_generic<union TrgbaPoint32>::doRelease(class Tevent const & __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\PolyUISlice.dll (-exported-)
Location: PolyUISlice.dllTpolySlideEdgeContext::checkForSnapping + 144FA bytes
Decl: private: float __cdecl TpolySlideEdgeContext::checkForSnapping(float) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTtoolContext::preDoRelease + 2D bytes
Decl: protected: virtual int __cdecl TtoolContext::preDoRelease(class Tevent const & __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\SharedUI.dll (-exported-)
Location: SharedUI.dllTstandardContext::preDoRelease + 218 bytes
Decl: public: virtual int __cdecl TstandardContext::preDoRelease(class Tevent const & __ptr64) __ptr64
Location: ExtensionLayer.dllTtoolCallback::doIt + 12 bytes
Decl: public: virtual bool __cdecl TtoolCallback::doIt(class Tevent const & __ptr64) __ptr64
Location: ExtensionLayer.dllTcontrol::doRelease + 54 bytes
Decl: protected: virtual int __cdecl Tcontrol::doRelease(class Tevent const & __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\3dGraphics.dll (-exported-)
Location: 3dGraphics.dllQmayaFontRaster::operator= + A64 bytes
Decl: public: class QmayaFontRaster & __ptr64 __cdecl QmayaFontRaster::operator=(class QmayaFontRaster const & __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Widgets.dll (-exported-)
Decl: protected: virtual bool __cdecl QWidget::event(class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 112 bytes
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplication::notify + 89E bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: ExtensionLayer.dllTwindowManager::windowPreferencesAreEnabled + 3CD bytes
Decl: public: bool __cdecl TwindowManager::windowPreferencesAreEnabled(void)const __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-)
Location: Qt5Core.dllQCoreApplication::notifyInternal2 + B9 bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Widgets.dllQApplicationPrivate::sendMouseEvent + 380 bytes
Decl: public: static bool __cdecl QApplicationPrivate::sendMouseEvent(class QWidget * __ptr64,class QMouseEvent * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64 * __ptr64,class QPointer<class QWidget> & __ptr64,bool)
Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + 2BA5 bytes
Decl: public: __cdecl QSizePolicy::QSizePolicy(void) __ptr64
Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + A65 bytes
Location: Qt5Widgets.dllQApplication::notify + 1B27 bytes
Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Gui.dll (-exported-)
Location: Qt5Gui.dllQGuiApplicationPrivate::processMouseEvent + 7F3 bytes
Decl: public: static void __cdecl QGuiApplicationPrivate::processMouseEvent(class QWindowSystemInterfacePrivate::MouseEvent * __ptr64)
Location: Qt5Gui.dllQWindowSystemInterface::sendWindowSystemEvents + 9B bytes
Decl: public: static bool __cdecl QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + DA8 bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Module: C:\Windows\System32\USER32.dll (-exported-)
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 4D6 bytes
Module: C:\Program Files\Autodesk\Maya2019\plugins\platforms\qwindows.dll (-exported-)
Location: qwindows.dllqt_plugin_query_metadata + 24B9 bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: Qt5Core.dllQCoreApplication::exec + 147 bytes
Decl: public: static int __cdecl QCoreApplication::exec(void)
Location: ExtensionLayer.dllTapplication::start + CE bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module: C:\Program Files\Autodesk\Maya2019\bin\maya.exe (-exported-)
Decl: ??
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + F504 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + E47F bytes
Module: C:\Windows\System32\KERNEL32.DLL (-exported-)
Module: C:\Windows\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\Talha\AppData\Local\Temp\MayaCrashLog200531.0100.log
//version = 19.0.7966.0
//cut = Tue 12/11/2018, 201812112220
//current scene = unDisclosed
//command history (most recent last):
//last tool: Move
//panel with focus: modelPanel4
//visible panels:
// modelPanel4 outlinerPanel1 polyTexturePlacementPanel1
//Memory usage:
// 2181.051 Mb Free Memory
// 7520.523 Mb Free Swap
// 1118.113 Mb Current
1 REPLY 1
dpatko
in reply to: talhahelvaci
I'm getting this all the time too. Maya 2019. Can't figure out what exactly is causing the issuer other that it is when I'm using the UV editor for a while. So frustrating. Any luck with a fix?
