Announcements
Maya render node on Centos libXpm.so.4 error
tech
tech
Hi All,
I'm setting up a deadline render farm with centos nodes and have installed all necassary libraries but I'm gett in a error when I try and run from the commandline:
/usr/autodesk/maya2018/bin/maya.bin: error while loading shared libraries: libXpm.so.4: cannot open shared object file: No such file or directory
I can see the Library in /usr/var/lib and it is accessible by the user.
Has anyone had this issue?
Mark
tech
Just realised, i'm running Centos 7.6 if that matters
warnold2
Maya 2018 is 64bit application.  the system libXpm.so.4 should be in /usr/lib64
rpm -qf /usr/lib64/libXpm.so.4
libXpm-3.5.12-1.el7.x86_64
sudo yum install /usr/lib64/libXpm.so.4
Wayne Arnold
Developer
tech
Thats brilliant, thanks very much
