Maya Prefs: enable backface cull with python/mel
16497643852
Message 1 of 8
16497643852
I have been trying to enable and disable backface cull in the maya prefs, but unfortunately it is not working for me. I am pretty sure i am missing out something really silly.
Please check the attached image
mel command
optionVar -list; // gives me the list of string names
optionVar -q newPolyBackFaceCull; // queried and confirmed this string is getting modified if i update manually in //prefs
optionVar -intValue newPolyBackFaceCull 1; // when i try to modify it does not work
any suggestions.
And additional query if this string is wrong, what would be the best way to find the list of strings?
Thank You.
Replies (7)
Message 2 of 8
The-Digital-Shaman
//Display back of faces
ToggleBackfaceGeometry;
//Backface Cull off
setAttr "pCubeShape5.backfaceCulling" 0;
//Backface Cull Full
setAttr "pCubeShape5.backfaceCulling" 3;
It is messed up tho, as it works only on what one manually changed in the Attribute Editor, prior to using the script.
I don't know how to make it apply globally or at least work on selection.
Anyone?
Message 3 of 8
brian.kramer
I believe you will have better success if you use the following commands to change backface culling in the Script Editor.
polyOptions -newPolymesh -backCulling;     // Off
polyOptions -newPolymesh -fullBack;        // On
polyOptions -newPolymesh -wireBackCulling; // Keep wire
polyOptions -newPolymesh -hardBack;        // Keep hard edges
These are the commands that are executed when you change the value with Preferences > Display > Polygons > Backface culling.
When Maya prefs are saved we sync this value up with the newPolyBackFaceCull optionVar.
Brian Kramer
Software Developer
Message 4 of 8
The-Digital-Shaman
Good try Brian!
For me these commands work from the Display options, but not when using code directly.
There must be something more to activate them.
Message 5 of 8
brian.kramer
After calling the various polyOptions commands create a new poly object. That new object should have the culling option you specified.
Try this script. It sets each culling option, creates a poly sphere, and queries the culling option.
file -new -force;
global proc printCulling()
    int $backCulling[] = `polyOptions -query -backCulling`;
    int $fullBack[] = `polyOptions -query -fullBack`;
    int $wireBackCulling[] = `polyOptions -query -wireBackCulling`;
    int $hardBack[] = `polyOptions -query -hardBack`;
    print("backCulling     = " + $backCulling[0] + "\n");
    print("fullBack        = " + $fullBack[0] + "\n");
    print("wireBackCulling = " + $wireBackCulling[0] + "\n");
    print("hardBack        = " + $hardBack[0] + "\n");
    print("\n");
polySphere -name sphere1;
printCulling();
polySphere -name sphere2;
printCulling();
polySphere -name sphere3;
printCulling();
printCulling();
Brian Kramer
Software Developer
Message 6 of 8
The-Digital-Shaman
Appreciate the effort. It does what you said plus erased everything from a scene.
I don't understand how does it solve anything though.
Message 7 of 8
16497643852
Thank You all for the amazing replies,
So what i want exactly is to mention the command in `userSetup.mel`
This resolves 2 problems,
1) it will always be enabled for the whole scene and not just per object(geo)
2) even if anyone resets the prefs i'll have those settings enabled automatically once again with the help of userSetup.mel/.py
polyOptions work mostly with selection list(ls) as far as i know.
i am still trying on my end, let me know in case you guys find anything related to prefs.
Thanks a lot guys🙂
Message 8 of 8
16497643852
To my surprise@brian.kramer , your option works. Thanks alot😁
`Prefs>display>polygons>backface culling>On`
%MAYA_APP_DIR%/<version>/script/userSetup.py
import maya.cmds as cmds
def dosomething():
    cmds.polyOptions(newPolymesh=True, fullBack=True)
    print("this is a test")
cmds.evalDeferred('dosomething()')
reference material
"D:\c_drive_installs\autodesk\Maya2023\scripts\startup\createPrefWndUI.mel" - the options @brian.kramer suggested, one can also refer it here
Unwanted stuff
I had checked polyOptions in the scene it did not work for me properly(or i did not use it properly😅), did not result me backface culling in the scene, but while going through all the options once again i noticed the option in `Prefs do update`
I was too adamant to solve it in this manner - because the docs say so
optionVar - This command allows you to set and query variables which are persistent between different invocations of Maya. These variables are stored as part of the preferences.
