Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
maya.OpenMayaUI MQtUtil_findControl
0 REPLIES 0
Message 1 of 1
MaYa_people
358 Views, 0 Replies
I have a string of python plugins, when I run it, the window cannot be created correctly, there is no problem in the 2023 version, but the 2024 version runs incorrectly, is it because of which key codes have been updated in 2024? The following is regardless of script and error.
import os
import sys
if not os.path.exists(r'D:\Documents\maya\MayaSceneConverter'):
raise IOError(r'The source path "D:\Documents\maya\MayaSceneConverter" does not exist!')
if r'D:\Documents\maya\MayaSceneConverter' not in sys.path:
sys.path.insert(0, r'D:\Documents\maya\MayaSceneConverter')
import ConverterUI
ConverterUI.ConverterUI()
AttributeError: file D:\Documents\maya\MayaSceneConverter\ConverterUI.py line 756: module 'maya.OpenMayaUI' has no attribute 'MQtUtil_findControl'
def getDock(wrap, name, label):
if cmds.workspaceControl(name, query=True, exists=True):
cmds.deleteUI(name)
ctrl = cmds.workspaceControl(name, r=True, rs=True, floating=True, label=label)
# tabToControl=('ChannelBoxLayerEditor', 1)
# dockToMainWindow=("right", True)
qtCtrl = omui.MQtUtil_findControl(ctrl)
ptr = wrapInstance(int(qtCtrl), wrap)
return ptr
0 REPLIES 0
