Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya instancer Every Frame ReCalculate Problem..!!
3 REPLIES 3
flashermak
385 Views, 3 Replies
When using Maya 2017 MASH instancer it re-calculates every frame even without animation on instances.
In case of we have millions of instances this is a big problem. When I moved to a frame it re-calculated and I wait for 40-60 secs. Is there a freeze function to prevent Maya to re-calculate instancer every frame? No animation on instances. I have only camera animation.
Render Engine: Redshift
Proxy: Redshift proxy objects.
3 REPLIES 3
mspeer
in reply to: flashermak
Hi!
Currently i only can suggest to lower the value for "Number of Points" inside the Distribute node (or World node),
or use a complete different baking/instancing solution.
You can also disable the MASH node temporarily as simply hiding has no effect.
flashermak
in reply to: mspeer
Thx mspeer. But this is not the solution...
@mspeer wrote:
Hi!
techEFH67
I have the same problem
Has anyone figured out how to fix this in 5 years?
