Maya in Mint: Possible workflow???
kyakouboff
kyakouboff
Hey folks, no one seems to have an answer for how to install Maya2026 in Mint, but DuckDuckGo’s AI provided the following for an answer. I do not know how viable this is, as I haven’t tried it yet. I’d be curious to see peoples’ opinions. (Sorry about any formatting issues here. I am not knowledgable enough in Linux command line syntax to know the best way these lines of commands out to be laid out.)
Here goes nuth’n...
To install Maya 2026 on Linux Mint, you may need to first install required dependencies using the terminal, then download the Maya package, and convert it if necessary. However, Autodesk primarily recommends using specific distributions like RHEL or Rocky Linux for better compatibility, so you might encounter issues on Linux Mint.
Installing Maya 2026 on Linux Mint
Prerequisites
Before installing Maya 2026, ensure you have the following:
• A compatible version of Linux Mint (preferably based on Ubuntu 22.04).
• Sufficient system resources (modern CPU, GPU, and RAM).
• Basic knowledge of using the terminal.
Installation Steps
1. Update Your System Open the terminal and run:bash
sudo apt update
sudo apt upgrade
2. Install Required Dependencies Install the necessary libraries by executing:bash
sudo apt install -y libaudiofile1 libxss1 libgconf-2-4 libxrandr2 libxcursor1 libxcomposite1 libxdamage1 libxfixes3 libxi6 libxrender1 libxtst6 libxxf86vm1 libgl1-mesa-glx libglu1-mesa libegl1-mesa libxkbcommon-x11-0 libxkbfile1 libxmu6 libxpm4 libxaw7 libxinerama1 libfontconfig1 libfreetype6 libxft2
3. Download Maya 2026 Obtain the Maya 2026 installation package from Autodesk's official site. You may need to convert the downloaded .rpm file to .deb format.
4. Extract and Install Maya Create a directory for Maya and extract the files:bash
mkdir maya2026
tar -xzf Autodesk_Maya_2026_1_Update_ML_Linux_64bit.tgz -C maya2026
cd maya2026/
Install the necessary .deb files:bash
sudo dpkg -i adlmapps31_31.0.4-1_amd64.deb
sudo dpkg -i adskflexnetclient_11.18.3-2_amd64.deb
sudo dpkg -i adskflexnetserveripv6_11.19.4-2_amd64.deb
sudo dpkg -i adsklicensing15.1.0.12339_0-1_amd64.deb
5. Install Additional Components If prompted, install the AdODIS package included in the Maya files. Follow the instructions carefully.
6. Create Symlink for TLS Certificates Run the following commands to create a symlink for TLS certificates:bash
mkdir -p /etc/pki/tls/certs
ln -sf /etc/ssl/certs/ca-certificates.crt /etc/pki/tls/certs/ca-bundle.crt
7.. Launch Maya After installation, you can start Maya from the terminal by typing maya or by finding it in your applications menu.
Troubleshooting
If you encounter issues, consider switching to an X11 session instead of Wayland, as some users have reported better compatibility with Maya in X11.
lauri_barnhart
Hi @kyakouboff,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
kyakouboff
No one has responded, except for you.
