Pretty much the title, when looking at my outbound firewall i can see several connections to Ip addresses that resolve to Google.com. This happens on multiple ports at once every 30 seconds the entire time maya is running. Is there a reason for this traffic?
I have these already set:
MAYA_DISABLE_CIP = 1
MAYA_DISABLE_CER = 1
MAYA_DISABLE_CLIC_IPM = 1
Hi @smbell1979
I believe this is Maya pinging just to check if there is an internet connection and/or looking for updates via the desktop app for example.
Is this causing any problems for you or were you just curious as to why it was happening?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @smbell1979
Just wanted to check in to see how things were going. Did the information I provided yesterday help at all?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
