Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya File Node with UV Set
1 REPLY 1
dhanad
417 Views, 1 Reply
I have 2 UV Set. First set is for Xgen. Second is for textures and displacement. While UV Linking works for anything plugged into the material, there is no way to UV link a displacement as it does not show up in the UV Linking list. One work around was to add a custom attribute and then UV link it. But it seems to not work properly with Arnold GPU. It works with Arnold CPU.
Anyone here know a way to specify which UV set to use to render displacement using the Maya's File Node or any specific node for that matter? Arnold's aiImage node has a way to specify UV Set to use but it seems broken.
1 REPLY 1
patrick.schock
in reply to: dhanad
Hello @dhanad,
please see this post in Arnold Answers: aiImage node, how to assign a UVset other then the default one?
Can you try to set the UV set in the aiImage node in the same way?
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
