Try deleting your prefs folder C:\User\Documents\maya\MayaVersion
This will essentially reset Maya to its defaults. If that doesn't work, you may need to reinstall the software.
Always looking to solve problems, if I'm helpful at all consider dropping a kudos!
Was there a CER report generated? If you have the #, or can give us an email you used to submit a report so that we can search for it, then that might help us figure out what is happening.
Something that could help to narrow down the problem would be to not load any plugins. You can do this by editing your pluginPrefs.mel file that you will find in your Maya prefs forlder. So somewhere like: C:\Users\<user>\Documents\maya\2016\prefs\pluginPrefs.mel. Try opening this file in a text editor and deleting everything in there.
Hi guys ,
I have the same problem. Most of the times is when I'm working in MASH or UV editor or even animate a text this error occurs.
Anyone have any idea how to solve this?
I have been trying everything that is on internet.
(Delete the pref folder, create an environment variables, update nvidia drives and change global subdivision method to maya catmull-clark.)
This error continues and I have no idea how to solve this.
Thanks in advance.
Cheers
