Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya dagContainer error
0 REPLIES 0
Message 1 of 1
chowooseung
95 Views, 0 Replies
Hello. I am currently working on a rigging system using containers.
It is not known which one is the trigger, but the following error occurs while repeatedly testing (delete, create) the rigging system.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/AETemplates/AEcontainerMain.mel line 1955: Object 'AttributeEditor|MainAttributeEditorLayout|formLayout1|AErootLayout|AEStackLayout|AErootLayoutPane|AEbaseFormLayout|AEcontrolFormLayout|AttrEddagContainerFormLayout|scrollLayout2|columnLayout9|frameLayout42|columnLayout12|columnLayout13|containerMemberLayout' not found. //
This error occurs whenever you select the "dagContainer" node. Does not occur on the entire "dagContainer" node. Occurs only on certain nodes.
When this error starts to occur, the following additional error occurs when changing viewMode on the dagContainer node
// Error: Error occurred during execution of MEL script
# file: C:/Program Files/Autodesk/Maya2023/scripts/AETemplates/AEcontainerMain.mel line 1955: Object 'AttributeEditor|MainAttributeEditorLayout|formLayout1|AErootLayout|AEStackLayout|AErootLayoutPane|AEbaseFormLayout|AEcontrolFormLayout|AttrEddagContainerFormLayout|scrollLayout2|columnLayout9|frameLayout42|columnLayout12|columnLayout13|containerMemberLayout' not found.
# Traceback (most recent call last):
#   File "C:\Program Files\Autodesk\Maya2023\Python\lib\site-packages\maya\internal\common\ae\template.py", line 197, in <lambda>
#     cmds.scriptJob(p=control, rp=True, ac=(plugName, lambda *a: changedCommand(plugNode(plugName))))
#   File "<maya console>", line 1, in <lambda>
# RuntimeError: Error occurred during execution of MEL script
# file: C:/Program Files/Autodesk/Maya2023/scripts/AETemplates/AEcontainerMain.mel line 1955: Object 'AttributeEditor|MainAttributeEditorLayout|formLayout1|AErootLayout|AEStackLayout|AErootLayoutPane|AEbaseFormLayout|AEcontrolFormLayout|AttrEddagContainerFormLayout|scrollLayout2|columnLayout9|frameLayout42|columnLayout12|columnLayout13|containerMemberLayout' not found. //
And this error is increasing...
Initially, one line is displayed every time you click the dagContainer node, but after you change viewMode, the error line that appears every time you click increases.
I am working on Maya 2023.1 windows11.
Tags (2)
0 REPLIES 0
