Maya crashes when saving file
Message 1 of 1
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000000
Fault address: E9E0E3E7 in C:\Program Files\Autodesk\Maya2017\bin\SharedUI.dll
0001:0007D3E7 Logical offset (see .map file for location)
Call stack:
(11) section:offset 0001:0007D3E7 Address: 0xE9E0E3E7 Frame: 0x549F7530
Module: C:\Program Files\Autodesk\Maya2017\bin\SharedUI.dll (-exported-)
Location: QmayaMiniNonModalColorPickerDialog::trUtf8 + 0x17F7 bytes
Decl: public: static class QString QmayaMiniNonModalColorPickerDialog::trUtf8(char const * ptr64,char const * ptr64,int)
Source: (0)
(12) section:offset 0001:0007D7AD Address: 0xE9E0E7AD Frame: 0x549F76F0
Source: (0)
(13) section:offset 0001:0000659D Address: 0xD7BD759D Frame: 0x549F77E0
Module: C:\Program Files\Autodesk\Maya2017\bin\Translators.dll (-exported-)
Decl: public: class TgeometryFile & ptr64 TgeometryFile::operator=(class TgeometryFile const & ptr64)
Source: (0)
(14) section:offset 0001:00413D04 Address: 0xECAF4D04 Frame: 0x549F7900
Module: C:\Program Files\Autodesk\Maya2017\bin\Shared.dll (-exported-)
Decl: public: int TfileTranslator::write(class TsceneFile & ptr64)
Source: (0)
(15) section:offset 0001:0040F406 Address: 0xECAF0406 Frame: 0x549F7CF0
Decl: public: static bool TglobalTranslator::writeFile(class TsceneFile & ptr64)
Source: (0)
(16) section:offset 0001:004092F8 Address: 0xECAEA2F8 Frame: 0x549F9110
Decl: private: bool Tscene::writeUIConfiguration(void)
Source: (0)
(17) section:offset 0001:00403B52 Address: 0xECAE4B52 Frame: 0x549F9180
Decl: public: bool Tscene::saveScene(bool)
Source: (0)
(18) section:offset 0001:004039CC Address: 0xECAE49CC Frame: 0x549F91D0
Decl: public: virtual bool Tscene::doSave(bool)
Source: (0)
(19) section:offset 0001:003DF56E Address: 0xECAC056E Frame: 0x549F9350
Decl: public: static bool TsceneOperator::saveScene(class Tstring & ptr64,class TsceneFile * ptr64,bool,bool)
Source: (0)
(20) section:offset 0001:003D86BE Address: 0xECAB96BE Frame: 0x549F93C0
Decl: private: bool TfileCmd::handleFileSaveFlag(class TargDatabase & ptr64,class TsceneFile * ptr64)
Source: (0)
(21) section:offset 0001:003D24C7 Address: 0xECAB34C7 Frame: 0x549F9430
Decl: protected: bool TfileCmd::handleFlags(class TargDatabase & ptr64,class TsceneFile * ptr64,class TnamespaceSwapper * ptr64,class TgraphDiff * ptr64)
Source: (0)
(22) section:offset 0001:003D1F05 Address: 0xECAB2F05 Frame: 0x549F9560
Decl: protected: bool TfileCmd::handleFlags(class TargDatabase & ptr64,class Tstring const & ptr64)
Source: (0)
(23) section:offset 0001:003CF402 Address: 0xECAB0402 Frame: 0x549F96E0
Decl: public: virtual bool TfileCmd::doCommand(class TargList & ptr64)
Source: (0)
(24) section:offset 0001:00016D63 Address: 0xFA587D63 Frame: 0x549F97D0
Module: C:\Program Files\Autodesk\Maya2017\bin\CommandEngine.dll (-exported-)
Decl: public: int TmetaCommandPtrArray::catenate(class TmetaCommandPtrArray const & ptr64)
Source: (0)
(25) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549F9820
Decl: protected: static char * ptr64 TminMelArgList::nextDigit(char * ptr64)
Source: (0)
(26) section:offset 0001:0003BA44 Address: 0xFA5ACA44 Frame: 0x549F9870
Source: (0)
(27) section:offset 0001:000650A0 Address: 0xFA5D60A0 Frame: 0x549F98A0
Decl: public: union Value * ptr64 SophiaExecutable::evaluate(void * ptr64)
Source: (0)
(28) section:offset 0001:0001E8FC Address: 0xFA58F8FC Frame: 0x549F98E0
Decl: public: int TcommandEngine::executeCommand(class SophiaExecutable * ptr64,void * ptr64)
Source: (0)
(29) section:offset 0001:0002B92B Address: 0xEDA6C92B Frame: 0x549F9950
Module: C:\Program Files\Autodesk\Maya2017\bin\ExtensionLayer.dll (-exported-)
Decl: public: int QmayaMenuItem::version(void)
Source: (0)
(30) section:offset 0001:00016D63 Address: 0xFA587D63 Frame: 0x549F9A40
Source: (0)
(31) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549F9A90
Source: (0)
(32) section:offset 0001:00066F71 Address: 0xFA5D7F71 Frame: 0x549F9AC0
Source: (0)
(33) section:offset 0001:0006664A Address: 0xFA5D764A Frame: 0x549F9B10
Source: (0)
(34) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549F9B60
Source: (0)
(35) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549F9BB0
Source: (0)
(36) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549F9C00
Source: (0)
(37) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549F9C50
Source: (0)
(38) section:offset 0001:00067614 Address: 0xFA5D8614 Frame: 0x549FA1D0
Source: (0)
(39) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549FA220
Source: (0)
(40) section:offset 0001:0003BA44 Address: 0xFA5ACA44 Frame: 0x549FA270
Source: (0)
(41) section:offset 0001:000650A0 Address: 0xFA5D60A0 Frame: 0x549FA2A0
Source: (0)
(42) section:offset 0001:0001E5D8 Address: 0xFA58F5D8 Frame: 0x549FA400
Decl: public: int TcommandEngine::executeCommand(class Tstring const & ptr64,bool,bool,class TmelCmdResult * ptr64,unsigned int)
Source: (0)
(43) section:offset 0001:001D9A48 Address: 0xEDC1AA48 Frame: 0x549FA4B0
Decl: private: bool TscriptAction::execute(class Tevent const & ptr64,class TinterpreterResult * ptr64 * ptr64)
Source: (0)
(44) section:offset 0001:00028D1D Address: 0xEDA69D1D Frame: 0x549FA5F0
Decl: public: virtual bool TrunTimeCommand::doCommand(class TargList & ptr64)
Source: (0)
(45) section:offset 0001:00016D63 Address: 0xFA587D63 Frame: 0x549FA6E0
Source: (0)
(46) section:offset 0001:000670F2 Address: 0xFA5D80F2 Frame: 0x549FABA0
Source: (0)
(47) section:offset 0001:00035C7D Address: 0xFA5A6C7D Frame: 0x549FABF0
Source: (0)
(48) section:offset 0001:0003BA44 Address: 0xFA5ACA44 Frame: 0x549FAC40
Source: (0)
(49) section:offset 0001:000650A0 Address: 0xFA5D60A0 Frame: 0x549FAC70
Source: (0)
(50) section:offset 0001:0001E5D8 Address: 0xFA58F5D8 Frame: 0x549FADD0
Source: (0)
(51) section:offset 0001:001D9A48 Address: 0xEDC1AA48 Frame: 0x549FAE80
Source: (0)
(52) section:offset 0001:0015436F Address: 0xEDB9536F Frame: 0x549FB0D0
Decl: public: static bool TinteractionDirector::doKey(class QKeyEvent const * ptr64)
Source: (0)
(53) section:offset 0001:0000F16D Address: 0xEDA5016D Frame: 0x549FB1A0
Location: TwindowManager::windowPreferencesAreEnabled + 0x55D bytes
Decl: public: bool TwindowManager::windowPreferencesAreEnabled(void)
Source: (0)
(54) section:offset 0001:001AB857 Address: 0x52C2C857 Frame: 0x549FB200
Module: C:\Program Files\Autodesk\Maya2017\bin\Qt5Core.dll (-exported-)
Location: QCoreApplication::notifyInternal2 + 0xA7 bytes
Decl: private: static bool QCoreApplication::notifyInternal2(class QObject * ptr64,class QEvent * ptr64)
Source: (0)
(55) section:offset 0001:000691F6 Address: 0x5223A1F6 Frame: 0x549FB230
Module: C:\Program Files\Autodesk\Maya2017\bin\Qt5Widgets.dll (-exported-)
Decl: public: QSizePolicy::QSizePolicy(void)
Source: (0)
(56) section:offset 0001:00067B07 Address: 0x52238B07 Frame: 0x549FB2A0
Source: (0)
(57) section:offset 0001:00016CB2 Address: 0x521E7CB2 Frame: 0x549FB2D0
Location: QApplicationPrivate::notify_helper + 0x112 bytes
Decl: public: bool QApplicationPrivate::notify_helper(class QObject * ptr64,class QEvent * ptr64)
Source: (0)
(58) section:offset 0001:00015C19 Address: 0x521E6C19 Frame: 0x549FB9F0
Decl: public: virtual bool QApplication::notify(class QObject * ptr64,class QEvent * ptr64)
Source: (0)
(59) section:offset 0001:0000EEB0 Address: 0xEDA4FEB0 Frame: 0x549FBAC0
Location: TwindowManager::windowPreferencesAreEnabled + 0x2A0 bytes
Source: (0)
(60) section:offset 0001:001AB857 Address: 0x52C2C857 Frame: 0x549FBB20
Source: (0)
(61) section:offset 0001:0002FEFF Address: 0xE91C0EFF Frame: 0x549FBBC0
Module: C:\Program Files\Autodesk\Maya2017\bin\Qt5Gui.dll (-exported-)
Location: QGuiApplicationPrivate::processKeyEvent + 0xFF bytes
Decl: public: static void QGuiApplicationPrivate::processKeyEvent(class QWindowSystemInterfacePrivate::KeyEvent * ptr64)
Source: (0)
(62) section:offset 0001:00032D16 Address: 0xE91C3D16 Frame: 0x549FBC10
Location: QGuiApplicationPrivate::processWindowSystemEvent + 0x146 bytes
Decl: public: static void QGuiApplicationPrivate::processWindowSystemEvent(class QWindowSystemInterfacePrivate::WindowSystemEvent * ptr64)
Source: (0)
(63) section:offset 0001:00016C2C Address: 0xE91A7C2C Frame: 0x549FBC50
Location: QWindowSystemInterface::sendWindowSystemEvents + 0x13C bytes
Decl: public: static bool QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
Source: (0)
(64) section:offset 0001:001F22EB Address: 0x52C732EB Frame: 0x549FBD40
Location: QEventDispatcherWin32::processEvents + 0xE1B bytes
Decl: public: virtual bool QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
Source: (0)
(65) section:offset 0001:00016281 Address: 0x1B5B7281 Frame: 0x549FBED0
Module: C:\WINDOWS\System32\USER32.dll (-exported-)
Source: (0)
(66) section:offset 0001:00015C53 Address: 0x1B5B6C53 Frame: 0x549FBF60
Source: (0)
(67) section:offset 0001:001F1A56 Address: 0x52C72A56 Frame: 0x549FF2C0
Location: QEventDispatcherWin32::processEvents + 0x586 bytes
Source: (0)
(68) section:offset 0001:00058599 Address: 0xD6999599 Frame: 0x549FF2F0
Module: C:\Program Files\Autodesk\Maya2017\qt-plugins\platforms\qwindows.dll (-exported-)
Source: (0)
(69) section:offset 0001:001A85C1 Address: 0x52C295C1 Frame: 0x549FF370
Decl: public: int QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>)
Source: (0)
(70) section:offset 0001:001AA65D Address: 0x52C2B65D Frame: 0x549FF3E0
Decl: public: static int QCoreApplication::exec(void)
Source: (0)
(71) section:offset 0001:00009B1A Address: 0xEDA4AB1A Frame: 0x549FF4E0
Decl: public: void Tapplication::start(void)
Source: (0)
(72) section:offset 0001:000021F3 Address: 0x421131F3 Frame: 0x549FF710
Module: C:\Program Files\Autodesk\Maya2017\bin\maya.exe (-exported-)
Source: (0)
(73) section:offset 0001:00024B75 Address: 0x42135B75 Frame: 0x549FF7A0
Location: TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator= + 0x146F5 bytes
Decl: public: class TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> > & ptr64 TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator=(class TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> > const & ptr64)
Source: (0)
(74) section:offset 0001:00021E98 Address: 0x42132E98 Frame: 0x549FF7E0
Location: TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator= + 0x11A18 bytes
Source: (0)
(75) section:offset 0001:00013034 Address: 0x1B744034 Frame: 0x549FF810
Module: C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
Source: (0)
(76) section:offset 0001:00072691 Address: 0x1CAA3691 Frame: 0x549FF860
Module: C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
Source: (0)
End of stack
//crash log file name = C:\Users\mayn\AppData\Local\Temp\MayaCrashLog191105.1156.log
//version = 17.5.3051.0
//cut = Tue 10/31/2017, 201710312136
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: modelPanel3
//visible panels:
// modelPanel3 outlinerPanel1 outlinerPanel3 modelPanel5
//Memory usage:
// 23960.051 Mb Free Memory
// 26702.262 Mb Free Swap
// 3334.082 Mb Current
Replies (0)
