Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
maya crash when opening file
2 REPLIES 2
dorany0805
118 Views, 2 Replies
//===================================================== Maya Crash Report //===================================================== Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x62085EFC Fault address: 5F9FB78A in C:\Program Files\Autodesk\Maya2024\bin\PolyEngine.dll 0001:0000A78A Logical offset (see .map file for location) Call stack: End of stack //crash log file name = C:\Users\doran\AppData\Local\Temp\MayaCrashLog240319.1541.log //version = 24.0.0.4640 //cut = 02/17/2023, 202302170737 //current scene = unDisclosed //command history (most recent last): //==================================================== //last tool: renderWindowSelectContextItem //==================================================== //panel with focus: modelPanel4 //visible panels: // modelPanel4 outlinerPanel1 //==================================================== //Memory usage: // 22703.992 Mb Free Memory // 28545.133 Mb Free Swap // 1308.375 Mb Current //====================================================
this is thr crash log.
already reinstalled maya and update graphic drivers but no luck there.
first crash happened when trying to scale a fairly simple object. since then i try to open the recoverd scene (yeah i know shoudlve saved) and the same crash happens on opening.
appreciate any help with this
2 REPLIES 2
Have you saved a .ma file?
https://linktr.ee/cg_oglu
yes
