Maya Command Window Error
elbell22
elbell22
Community Visitor
Community Visitor
I am currently trying to start up Maya to work on a school project. I am receive this error message in the command window when Maya is trying to start
// Error: line 0: Flags must come before objects: -DESKTOP //
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem". //
// Loading Bifrost version 2.2.1.0-202102081428-b33b49f
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: midgard, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found. //
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found. //
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item. //
// Warning: file: C:\Users\eabel\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\eabel\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\eabel\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\eabel\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// AbcExport v1.0 using Alembic 1.7.5 (built Nov 30 2020 18:40:46)
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already. //
import arnold
// Successfully imported python module 'arnold'
import mtoa
// Successfully imported python module 'mtoa'
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
// Successfully registered renderer 'arnold'
updateRenderOverride;
// AbcImport v1.0 using Alembic 1.7.5 (built Nov 30 2020 18:40:46)
// Error: line 1: Cannot find procedure "rebuildShowMenu". //
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/ModCreateMenu.mel line 1182: menu: Object 'mainCreateMenu' not found. //
# Error: RuntimeError: file C:\Program Files\Autodesk\Maya2022\plug-ins\sweep\scripts\sweepMenuItems.py line 30: Error occurred during execution of MEL script
file: C:/Program Files/Autodesk/Maya2022/scripts/startup/ModCreateMenu.mel line 1182: menu: Object 'mainCreateMenu' not found. #
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2022/2.2.1.0/bifrost/scripts/bifrostGraphMenu.mel line 327: menu: Object 'mainCreateMenu' not found. //
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/MayaUSD/Maya2022/0.8.0/mayausd/MayaUSD3/plugin/adsk/scripts/mayaUsdMenu.mel line 55: menu: Object 'mainCreateMenu' not found. //
// Performing AutoSave at 2021/05/14 15:23:32:
// master file: __AUTO-SAVE__untitled.mb
// AutoSave file: C:/Users/eabel/OneDrive/Documents/maya/projects/default/autosave/__AUTO-SAVE__untitled.0001.mb
// Error: line 1: Cannot find procedure "fileCmdCallback". //
I have uninstalled and reinstalled my Maya and Autodesk twice now, as well as run a disk repair and am stilling have this issue.
I  am working on a 64 bit windows 10 pro machine.
Thank you
Elizabeth
hamsterHamster
The use of OneDrive raises questions. Can you change it's settings, so your Maya settings are located in c:/users/eabel/documents/maya/ ? I have no experience with OneDrive, yet it is known Maya being picky about the user profile paths.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
aakashchaurasiya872
Observer
Observer
I am also having the same problem
aakashchaurasiya872
Observer
Observer
I'm in trouble from last 2 days but i cannot able to fine any solution till now can any one help me out from this problem.
aakashchaurasiya872
Observer
Observer
Help me out please with this problem
// Error: Flags must come before objects: -JACKPC //
# Error: AttributeError: file <maya console> line 1: module 'vaccine' has no attribute 'phage' #
# Error: NameError: file <maya console> line 1: name 'leukocyte' is not defined #
// Warning: file: C:\Users\aakas\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\aakas\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\aakas\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\aakas\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Curves / Surfaces" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Poly Modeling" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Sculpting" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Rigging" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Animation" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Rendering" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "FX" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "FX Caching" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Custom" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Arnold" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Bifrost" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "MASH" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Motion Graphics" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "Custom_Rigging" already exists. //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/shelf.mel line 202: The shelf "XGen" already exists. //
// Error: toolButton -q -ann $gNonSacredToolWidget; //
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable. //
// Error: line 1: Cannot find procedure "openRecentFile". //
file -f -new;
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/setNamedPanelLayout.mel line 247: Cannot find procedure "updateToolbox". //
// untitled //
// Error: line 1: Specified layout not found. //
jameseggleton
Community Visitor
Community Visitor
Same here
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "Animation" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "Arnold" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "MASH" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "Motion Graphics" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "Poly Modeling" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "Rigging" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/shelf.mel line 202: The shelf "XGen" already exists.
// Error: Flags must come before objects: -KITT
// Error: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found.
// AbcExport v1.0 using Alembic 1.8.5 (built Sep 19 2024 06:28:52)
import arnold
import mtoa
import mtoa.viewport;mtoa.viewport.add_controls()
// Bifrost: Pre-loaded mayaUsdPlugin to access proper Maya USD libraries.
// Loading Bifrost version 2.11.0.0-202407230615-0d4f172
// Error: Bifrost: The user's default publishing location does not exist: C:/Users/james/Autodesk/Bifrost/Compounds
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: boss, from: Autodesk.
// Bifrost: Loading library: rigging, from: Autodesk.
// Bifrost: Loading library: wedging, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
// Bifrost: Loading library: riggingMayaTranslations, from: Autodesk.
// Bifrost: Loading library: usd_pack, from: Autodesk.
// Bifrost: Loading library: usdMayaTranslations, from: Autodesk.
// Error: file: C:/Program Files/Autodesk/Maya2025/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found.
// AbcImport v1.0 using Alembic 1.8.5 (built Sep 19 2024 06:28:52)
// Error: file: C:/Program Files/Autodesk/Maya2025/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# Error: RuntimeError: file C:\Program Files\Autodesk\Maya2025\plug-ins\sweep\scripts\sweepMenuItems.py line 30: Error occurred during execution of MEL script
# file: C:/Program Files/Autodesk/Maya2025/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/MayaUSD/Maya2025/0.30.0/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsdMenu.mel line 57: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2025/2.11.0.0/bifrost/scripts/bifrostGraphMenu.mel line 409: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/LookdevX/Maya/2025/1.6.0/plug-ins/lookdevx/scripts/LookdevXGraphMenu.mel line 124: menu: Object 'mainCreateMenu' not found.
