Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya Command line Render - issue
2 REPLIES 2
mgidney
490 Views, 2 Replies
Hi.....  I am setting up a render farm here and the remote command being sent to the machines is something like this....
Render -r mr -proj /Volumes/Renderfarm/Render4/mattgidney/maya_test_project /Volumes/Renderfarm/Render4/mattgidney/maya_test_project/mr_test_0001.ma
The command fails with this message....
 *** Fatal Error: Failed creating directory: /Autodesk/maya 2014-08-04 10:22:59.213 MayaBatch[38490:1107] invalid CoreGraphics connection Maya could not create the necessary startup directories. Please check for sufficient disk space and necessary write permissions. // Maya exited with status 0 ====[2014/08/04 10:23:00 process complete, exit code: 0]====
Why is maya trying to create /Autodesk/maya on the render node?
What is happening here?  I saw from a RUSH thread about a similar topic that this is a misleading error and the issue is that maya cannot find the user home directory....
http://seriss.com/rush.103.00/rush/rush-td-faq.html#TDFAQ-MayaHome
Anyone can shed some light here?
Matt
2 REPLIES 2
mtb_yoshida
in reply to: mgidney
same thing happens here.
In our case, most of render machine in our office have no problem but a few do.
mattgidney
this annoying problem still persistes - can autodesk plese suggest what is happening in the back end?  why is an /Autodesk/maya directory even required for maya-batch -command on OSX???
Is this a fallback if there is no home directory?
