i need some help...
I'm tring to bake texture with alpha information using a mental ray mia material.
The scene is this:
I would like bake glass texture...but using Mental ray baking i have this:
No higlihts and no transtaprent material... I'v use this settings:
How can i fix?
Hi @ambrosi.fabio and welcome to the community!
I'm a little confused by your issue. Do you mean render the transparency not bake?
Also, your second screenshot looks like a top down view of the scene and is a bit confusing trying to see where the issue is.
When you get a chance, can you please post some additional information and screenshots or zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can get a better idea of what's happening?
Let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Ok, yes 🙂 i'll try to explain:
I have this virtual set and i'm trying render texture on a file (using batch bake mental ray).
When i try render solid texture (like a wall or ground) no problem but when i try render glasses (or semi transparent material) i can't catch alpha information and material is 100% solid. (or white).
So, for example, if i have this transparent material
i'd like catch only hilight and shining in texture file..
I know, sorry for my english.. i don't know if you understand what i mean.
Ah ok I understand now.
It may depend on how your scene is set up, lights etc.
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
All the best,
Sean Heasley
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
