Maya 2026 Plugin Load Error — Need Help
abdelhalim_abulmagd
abdelhalim_abulmagd
I downloaded the Maya 2026 Dev Kit from Autodesk’s website, and whenever I try to load my plugin, I keep getting this error:
// The specified module could not be found.
// Error: file: C:/Program Files/Autodesk/Maya2026/scripts/others/pluginWin.mel line 316: The specified module could not be found.
// (testPlugin)
I also tested build with the Dev Kits for Update 1, Update 2, and Update 3 — but I still get the same error every time.
I’m using Qt in my plugin:
Qt 5.15.2 — msvc2019_64
Then I tried building with:
Qt 6.8.2 — msvc2022_64
But I still get the same issue — the plugin won’t load inside Maya.
If anyone has run into this before or knows what might cause this, I’d really appreciate the help.
abdelhalim_abulmagd
I think the issue was because I was using the library downloaded directly from the Qt website.
While I was checking the files in the Maya dev kit, I found a folder named Qt, so I used the .lib files from there, and it worked.
The plugin loaded successfully.
