Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2024 Ubuntu 22.xx Install.
1 REPLY 1
david.ostler2WSX9
492 Views, 1 Reply
The only thing that seems to have changed in the 2024 install of maya is the following line.  Use existing maya/ubuntu 22 guides and use this line to register Maya.  Good news,  the home screen finally works!
sudo /opt/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register -pk 657P1 -pv 2024.0.0.F -el EN_US -cf /var/opt/Autodesk/Adlm/Maya2024/MayaConfig.pit
Tags (2)
Labels (1)
1 REPLY 1
For some weird reason the latest Ubuntu kernel is built with gcc-12 and only gcc-11 is installed on Ubuntu 22.0.4.  I needed to Install GCC-12 before I could compile NVIDIA drivers which requires that you use the same gcc as the kernel was compiled with.
After a fresh install of Ubuntu 22.04 here's what I did to prep for the Maya install:
sudo apt update
sudo apt upgrade
sudo apt install build-essential libglvnd-dev pkg-config
sudo bash -c "echo blacklist nouveau > /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
sudo bash -c "echo options nouveau modeset=0 >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
sudo update-initramfs -u
sudo reboot
sudo apt install gcc-12 g++-12
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-11 60 --slave /usr/bin/g++ g++ /usr/bin/g++-11
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-12 70 --slave /usr/bin/g++ g++ /usr/bin/g++-12
sudo update-alternatives --config gcc
#(select gcc-12 here)
mkdir ~/install; cd ~/install
wget https://us.download.nvidia.com/XFree86/Linux-x86_64/535.154.05/NVIDIA-Linux-x86_64-535.154.05.run
chmod +x NVIDIA-Linux-x86_64-535.154.05.run
sudo ./NVIDIA-Linux-x86_64-535.154.05.run
