Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2024 "unsmooth" creates corrupt geo
4 REPLIES 4
johnkeates2865
243 Views, 4 Replies
I sent a bug report with the official form but I have no reply saying that it was even recieved and the form had no way to attach files - so adding here also:
The new "Unsmooth" modifier is great to see but seems to create corrupt geo!  To reproduce:
> Make a torus
> Apply the "Unsmooth" deformer
> I Find I now can't use the multiCut tool to split edges. Also, if you now apply "Smooth", the geo looks spikey and there are odd ghost edges (image attached).
4 REPLIES 4
If you create a torus you have first to use smooth to get a smoothed surface.
The unsmooth deformer is inverse smooth. Its needs to used on smoothed surfaces.
Its ment to be used on meshes coming from sculpting tools. Its not a reduce tool.
In the case of a torus it does work cause it might find a similar subD than a smooth but its not.
Thats why its failing in your case.
As you can see on my example it does work fine.
https://linktr.ee/cg_oglu
brentmc
in reply to: johnkeates2865
Thanks. We've opened an new issue on this for investigation.
As mentioned in the other reply this function is for unsmoothing subdivided surfaces but I would have expected an error message. (like what happens when you try to run unsmooth on a default sphere)
Brent McPherson
Principle Engineer
Yes, there should be an error message blocking you from unsmoothing a mesh until it gets corrupt.
The thing is, there is no clear way to know if you have unsmoothed too much.
Actually, I did test before with smoothing before unsmoothing and I got the same corruption, but that is because I unsmoothed as much as I could.
In short - the tool shouldn't produce corrupt geo 🙂
syracoj
We have logged MAYA-128650 against this issue on your behalf.
