Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Maya 2024 crashes when disabling Arnold
mattock
mattock
Hi, I need to disable the Arnold plugin as it doesn't work with vray cosmos.  Anyway, every single time I try and turn it off  in the plugin manager, it crashes Maya.
If I turn it off in a new blank scene it works, but it seems I need to turn it off for all my scene files separately, and when I have a saved scene and try and turn it off, it crashes every time
I'm using Maya 2024, any help appreciated
Many thanks
Christoph_Schaedl
The easiest fix would be to uninstall Arnold if you dont need it.
https://linktr.ee/cg_oglu
mattock
Thanks, but I do use Arnold as well as Vray, so ideally don't want to uninstall it.  I just need to be able to disable it.
Why does it turn off ok with a blank fresh scene, but disabling it in any saved file crashes Maya?
Stephen.Blair
What do you mean by "disabling it" ?
Unloading the mtoa plugin? You won't be able to do that while there are MtoA nodes in the scene (like defaultArnoldRenderOptions).
// Stephen Blair
// Arnold Renderer Support
holyshiptees
I'm having this issue too, its really annoying.
