Hi.
Pressing F in the viewport will frame an object or selected component.
But, i just noticed, when an item is isolated (CTRL+1) the "F" command will only frame the entire object, but not the component that is selected on that object.
I already went through the hotkeys and found nothing unusual.
Frame Selected is bound to the F key, as it should be and as i said, it will focus on components, but only if the object is not in isolated view.
I'd swear this was different in previous maya versions, but i cant check due to this issue --> Maya 2022 - Installation error - Autodesk Community - Maya
Anyway.
I'd like to know if this is expected behaviour for maya 23 and if so, how can i change it, so it will focus on components also in isolated view ?
