Maya 2023 Component Selection Issues
kharlingP5YDV
Message 1 of 20
kharlingP5YDV
I just installed 2023 and I'm having a strange issue with selecting components. When I click one face at a time, for example, the most recently selected face does not highlight until I select another face then the previously selected face highlights. Also if I double click an edge it only shows the one edge highlighted and not the whole loop but the modeling toolkit panel shows multiple edges are selected. This seems to happen in the isolate select window and not the full view window.
Replies (19)
Message 2 of 20
200407AAGAH
Observer
Observer
I have the exact same issue. Its becoming a bit annoying. Has anyone found a solution for this yet?
Message 3 of 20
damaggio
Works fine here, can you post your specs please.
Message 4 of 20
200407AAGAH
Observer
Observer
Yess
CPU: intel core i7 8th gen
GPU:NVIDIA GeForce GTX 1070, latest driver installed
32 GB RAM
Message 5 of 20
kharlingP5YDV
It seems to be related to this issue https://forums.autodesk.com/t5/maya-forum/maya-2023-f-to-frame-components-in-isolated-view-bug/m-p/1... but the only workaround is patching it myself which I don't know ow to do. I attempted to but it broke my install and I had to reinstall 2023.
Message 6 of 20
200407AAGAH
Observer
Observer
Hmm to bad, I guess we'll just have to wait for a fix then. thanks for responding anyways 🙂
Message 7 of 20
brentmc
Maya 2023.1 was just released:
https://www.autodesk.com/maya-releasenotes
https://www.autodesk.com/maya-whatsnew-2023-enu
Brent McPherson
Principle Engineer
Message 8 of 20
damaggio
CamBookmarks.jpgThanks Brent, I'm glad that the shelf Icon label now works, however the camera bookmarks still don't retain the name, it just keeps saving "CameraView1..2..3 etc.
Message 9 of 20
kelly_hynes
How are you saving bookmarks?  Following this workflow, I was able to get it to work as expected:
https://www.youtube.com/watch?v=LKUA1KrnkP4
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 10 of 20
damaggio
 Yes , that's exactly how I've always done and trying to rename after creating it also doesn't do anything. I just tried again.Also deleted my preferences and did it again. That was for perspective cam, create a new camera and try to bookmark any angle and it does not save.Windows 10
I sent you a screencast Kelly, thanks..
Message 11 of 20
sepu6
it works fine here 2023.1
Message 12 of 20
damaggio
Thanks @sepu6 but mine is not saving at the moment unfortunately.👍
Kelly Hynes just suggested hitting "Enter or Return " in the keyboard and that works 👌 , however the Apply button seems to be failing. Also renaming works with the keyboard.
Message 13 of 20
kelly_hynes
It works for me as long as I press return after entering a new name in the bookmark editor.  If I use the 'Apply' button, it does not work.  Sometimes I have an error in the Script Ed.  I will log this defect.
Kelly
Kelly Hynes
Message 14 of 20
kharlingP5YDV
Thanks Brent, I downloaded the update just waiting for it to install.
Message 15 of 20
kharlingP5YDV
The update helped the framing issue but not the highlighting issue. As an example here I have 4 faces selected but only 3 are highlighted. This only happens in isolation mode. highlightissue.png
Message 16 of 20
ml0428539
I also have highlighting problems in isolate select. when i isolate select some faces then select a single one among them, the face highlighted is not the one I currently select but the previous one. though ls command looks correct so i guess it's just a highlighting issue
Message 17 of 20
kelly_hynes
I've reproduced the issue you describe with highlighting/isolate select.  I'm following up.  Thank you for reporting.
Kelly
Kelly Hynes
Message 18 of 20
kelly_hynes
Update:
I've logged this issue:
MAYA-124176 Selection highlighting incorrect with isolate selected components
The dev team is investigating.
Kelly
Kelly Hynes
Message 19 of 20
Kloworks
so what the solution is there a hotfix or do we need to wait 4 months ?
Message 20 of 20
lishuang4L946
您好,问题解决了吗?我目前使用的是最新版本的 2023.1。我仍然在 Isolatre 选择模式下选择模型上的曲面或线,但仍然存在无法显示的问题。
