Maya 2022/Win: importing alembic sequence weirdness
patrickY3GAB
patrickY3GAB
Hello and thank you in advance. I am using Bifrost to export a series of Alembic files for my simulation. I tried importing these back into Maya, but Maya only imports one frame/abc file at a time.
So, I went to RealFlow and used their Alembic Stitcher tool. This tool took my 50 Alembic frames and created one ABC file.
However, when I import this into Maya I have problems. This time, I do get a full 1-50 frame import. However, it is imported not as a sequence but instead as individual frames. And these appear stacked on top of each other in the viewport.
I would like to import an Alembic sequence into Maya and have it play back.
I clearly am overthinking this, right? What silly little thing am I missing?
Thank you!
patrickY3GAB
Dude, you are SO overthinking it. There's a little checkbox when you export Alembic in Bifrost.
"Write Single File"
patrickY3GAB
Thanks! This works!
martinmichl
I have the same problem, cause when I check "Write Single File", Maya tells me "this is not a valic Alembic file"
