Maya 2022 Startup Bug
eoghangarvey
eoghangarvey
I've installed Maya 2022 but it fails to start up. I get an error prompt saying :
"Color Management Initialization failed: "Error could not read 'C:/Program Files/Autodesk/Maya2020/resources/OCIO-configs/Maya2022-default/config.ocio' OCIO profile." from the preference file "<MAYA_RESOURCES>/OCIO-configs/Maya2022-default/config.ocio".
It seems to be trying to read from a directory that doesnt exist in the Maya 2020 installation for some reason instead of Maya 2022.
Any help appreciated!
Replies (19)
albin.nocode
I had the same error this morning, but I remembered that I had setup the MAYA_LOCATION environment variable to point directly to my maya 2020 installation, and when I deleted that it worked as expected. Could be something to look at.
eoghangarvey
Fixed! Thank you 🙂
I had the same issue, did anyone find the solution.
albin.nocode
@Anonymous , did you try checking your environment variables?
Try to download it again
wynandlens
NO! DO NOT DOWNLOAD IT AGAIN. This is a pointless "Help" comment. Check your Environment Variables, Especially MAYA_LOCATION.
software
For me it was the OCIO environment variable. After deleting that one it worked again.
olegmironov1987HYYDS
Observer
Observer
Hello. please help me how to solve the problem?
Need detailed instructions. Thank you.
Observer
Observer
brentmc
If you look at the error message you can see that color management is looking under the Maya 2020 install path for a Maya 2022 file.
The solution is already provided here.
Check you system environment variables and remove any that contain "Maya2020". (probably MAYA_LOCATION or one another one related to OCIO)
Brent McPherson
Principle Engineer
Observer
Observer
Should I do something with these folders?
brentmc
No, you should check your system environment variables or Maya.env file for something that is referring to Maya2020 because (from your previous error message) you have something set which is causing Maya to lookup files in the wrong place.
Brent McPherson
Principle Engineer
Observer
Observer
I'm sorry, I don't understand how to do this?
Do you have a photo or video example?
brentmc
First I would check whether you have a Maya.env file and what things are in it. (as described in the help link below)
https://help.autodesk.com/view/MAYAUL/2023/ENU/?guid=GUID-8EFB1AC1-ED7D-4099-9EEE-624097872C04
Next, check your system environment variables.
Brent McPherson
Principle Engineer
mvotagT
Community Visitor
Community Visitor
Is it possible that there are no Maya-related variables in the system variables?
mvotagT
Community Visitor
Community Visitor
u20221a913
Community Visitor
Community Visitor
Hi, i have this issue with Maya and it's the first time that I installed this program, so I don't know what to do
wynandlens
Looks like you will need to delete your documents/maya/prefs folder.
That will reset may to default.
thms_valensousa
New Member
New Member
Ok, there are a lot of solutions apparently, but what worked for me was changing the location of my Maya files. So if you installed it on you desktop, try moving them to your documents and open it again
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
