Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2022 starting up error
1 REPLY 1
baconbaccaking
472 Views, 1 Reply
I have an educational license for Maya 2022. I tried downloading and installing it and when it finishes and starts up Maya closes and a new pop-up comes up.
After a while errors also pop up as well.
Does anyone know what this is or how to fix this problem? It won't let me start up Maya 2022 this way.
1 REPLY 1
Hello @baconbaccaking,
I would recommend the following steps:
1. Did you disable popup blocker when downloading the Maya 2022 installation files? Make sure that 2 files are downloaded when downloading the files from your Autodesk Account:
In case you need the installer files:
Autodesk_Maya_2022_ML_Windows_64bit_dlm_001_002.sfx.exe
Autodesk_Maya_2022_ML_Windows_64bit_dlm_002_002.sfx.exe
2. If you need to install Maya again, please perform a Clean Uninstall in advance: Perform a clean uninstall.
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
