Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2022 Output Window Doesn't show up on launch
2 REPLIES 2
payos6JMEV
1544 Views, 2 Replies
Hi! so I just updated to maya 2022 from 2020 and whenever I launch maya 2022 the output window doesnt show up anywhere. Is there a way to toggle it in the program/ is my install messed up?
When I launch maya 2020 the output window still pops up.
2 REPLIES 2
Stephen.Blair
in reply to: payos6JMEV
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Maya-Ani...
You can open the Output Window via Windows > Output Window. You can also show/hide it with the outputWindow command.
https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-57F72C64-401A-4273-9B16-23FF57C46605
... you can use the environment variable MAYA_SHOW_OUTPUT_WINDOW to force it to show on every startup.
// Stephen Blair
// Arnold Renderer Support
payos6JMEV
in reply to: Stephen.Blair
Thanks so much! All the stuff I found while googling was for previous versions and how to disable the output window.
