Maya 2022 normal-based mapping error
Jesse.Cushing001
Jesse.Cushing001
I just switched from Maya 2020 to Maya 2022 and when I attempted to use normal-based mapping in the uv editor I received the following error message
"// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/texNormalProjection.mel line 82: Invalid path 'polyTexturePlacementPanel1'."
I deleted my preferences but that did not fix the issue. Does anyone know how I can fix this?
Jesse.Cushing001
I uninstalled through add or remove programs and did a fresh install, but it did not fix the issue.normal-based mapping error-.JPG
Jesse.Cushing001
I was looking at the mel script mentioned in the error message and the line giving the error involves the active panel. I tried using both normal-based mapping options in the UV editor and both gave the error. However, using the normal-based mapping button in the UV editor dropdown menu above the shelfs does work correctly. I attached an image showing the options which do not work marked in red and the one that does work marked in green. error normalBased mapping.jpg
mspeer
Hi!
I can confirm this issue.
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
Still no fix for this?
