Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2022 Create VR with Quest 2 Link?
6 REPLIES 6
jdswiney
1596 Views, 6 Replies
Has anyone tested whether or not the Quest 2 with Link cable will work with Maya 2022 Create VR?
6 REPLIES 6
a.robinson19
in reply to: jdswiney
I've got it working with the older Quest using Oculus link.. it seems to run fine... I'm using a 1080 Nvidia card and a 3rd party usb 3.1 cable ,so I'd assume you should be ok, just make sure you graphic card is to spec
jdswiney
in reply to: a.robinson19
Thanks for the reply. 👍 I got it working perfectly on the Quest 2. Was unable to even try it due to that black screen issue with the PC software over the last few days. I don't know if that affected all customers or just new ones.
r0807970
how do you run it?
I installed Create VR and Maya 2022 but I can't find Create VR on my PC.
How do I launch into Create VR?
I also have a quest 2
jdswiney
in reply to: r0807970
Create VR is a plugin so you will need to go to the Plug-in Manager and
find CreateVRMayaPlugin.py and load it. It will put a menu item called
VR. Select it and click Open Create VR . It's best to have your Quest 2
linked to your PC before you start Maya. It will sense your Quest 2 and
stream the data to it.
epatrick15
I have it running using oculus link, however my controls are stuck in the HTC vive format. Any tips on how to change them back to the oculus layout?
qzwbla
in reply to: epatrick15
me too,how to change them back to the oculus layout?
