Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2022.3 Fails to startup
2 REPLIES 2
assafhaft
779 Views, 2 Replies
Hey guys looking for help with installing maya 2022.3.
I wanted to check out the new features so i went on on installing it, but after several attempts of troubleshooting i still cant get it to work.
I encounter these errors on startup every time:
loadPlugin renderSetup;
// renderSetup //
// Error: toolButton -q -ann $gNonSacredToolWidget; //
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable. //
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/performNewScene.mel line 86: Invalid argument: //
I have tried and checked a few threads talking about similar errors, but their solution haven't worked so far.
Things I've tried:
- Installing Uninstalling.
- removing/renaming Prefs & Scripts.
- using old maya prefs.
- installing maya 2022.0.
Here's a screenshot to show a bit more:
Thanks and if any other info is needed just tell me!
2 REPLIES 2
patrick.schock
in reply to: assafhaft
Hello @assafhaft,
I would suggest the following procedure:
1. Perform a clean uninstall of Maya, following the steps from here (make sure that all listed folders are deleted on your system): Perform a clean uninstall.
2. Download Maya 2022.3 and make sure that all 2 (!) installers are downloaded. Disable popup blockers in case that only one installer is downloaded.
3. Start Maya as Administrator and check if a Maya version folder is being created at this file path:
C:\Users\<username>\My Documents\Maya\<version>\
Looking forward to your reply if you had success.
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
JustineJustino
i have the same error, I'am in the final of my college project and i need Maya, did you already get the solution? pls help me aaaaa
