Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2020 Wont open, tried every solution on forums, still doesn't work
2 REPLIES 2
oceanjd
191 Views, 2 Replies
Hi
maya 2020 does not open. It opens up with a blank output window and then closes itself after a while.
What I've tried:
Deleting and reinstalling AdskLicensing.
Checking if Flexnet licensing is on automatic and is running.
Reinstalling and updating to the latest maya 2020.4
Does anybody else share this issue, or have any solution that might work?
Labels (1)
2 REPLIES 2
lucericr
in reply to: oceanjd
after you install maya, make sure to reboot, otherwise an older licencing service might still be running.
Then you need to verify that you don't have user preference, startup scripts, etc that might have errors in them and causing maya to error out on load. One way to rule that out is to try to run the software in another other user account on the machine.
n8skow
Has Maya worked on this machine previously?
