Maya 2019 object translating issue
dersutton
dersutton
I reinstalled Maya 2019 and began to experience strange issues.    I created a Poly Cylinder just to check to make sure everything was working.   I tried to translate the object when the problem appeared.
-There are no lights in the scene.
I've attached a screenshot to illustrate what is happening.
The object is selected but when I drag the move tool the cylinder turns white, remains in place and only the move tool moves.  When I deselect the move tool only then does the cylinder snap to the new location.
I did reset the move tool options but nothing has changed.  I restarted Maya as well but to no effect.
If somebody has any suggestions to share I would appreciate your input.
Thank you.
hamsterHamster
Maya certified hardware? If you have the latest video drivers, have you checked older, not too old ones?
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
dersutton
Hi
Sorry for the late reply.  I didn't receive any notice of your letter.
Yes, all of my drivers are up to date.  In fact, a few days later the problem vanished and everything appears to be working normally.    Glitch?  I'm starting to think so.
Thanks again.
hamsterHamster
Occasionally, I experience a similar issue, just without the white thing, and it "resolves" restarting Maya. Because of the white color, I assumed it is driver issue, as sometimes, especially earlier on cheaper (uncertified) nVidia geForces I've seen various issues (no UI elements, freezing etc) that I was lucky to solve by picking the right version of the drivers.
,,,_°(O__O)°_,,,
dersutton
For some reason the issue has resolved itself.   Another mystery of Maya I suppose.
Thanks again.
