Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2017 update 3 layered texture broken
7 REPLIES 7
Message 1 of 8
1010 Views, 7 Replies
Layeredtexture node seems to be broken since Maya 2017 Update 3. The alpha inputs of the layered texture do not work.
1: Create ramp or file node
2: Create layeredTexture node
3: Connect ramp1.outColor.outColorR to layeredTexture1.inputs.alpha
And now you see that the layeredtexture thumbnail doesn't update with the alpha, with rendering it also doesn't work.
We are using linux.
7 REPLIES 7
Message 2 of 8
Seems like the alpha of a file node is also broken?
Message 3 of 8
mspeer
Hi!
Here it works in Viewport and in Rendering, maybe you use a combination of nodes that isn't supported in the Renderer you use.
Please upload a scene-file.
Message 4 of 8
in reply to: mspeer
Found out that only the thumbnail is broken, it does render in my current test.
Message 5 of 8
mspeer
Hi!
You are right, the rendered icon does not reflect connected "alpha textures".
You can report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Message 6 of 8
Nadja.Bueckmann
in reply to: mspeer
Hi @Anonymous,
I reported the issue to our development department.
They are now having a look into it.
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
Message 7 of 8
tim.reed
in reply to: Nadja.Bueckmann
They are no longer working in Legacy Viewport as well.
Message 8 of 8
in reply to: tim.reed
still broken in Update 4
