Working with a relatively small 5MB mash file (Maya 2017 U3), I've found quite a severe memory leak that eats through 16GB ram in under an hour.
This is just from working with the scene and scrubbing in the timeline, not adding anything new to the scene. There are no textures or materials in the scene, just working with a few repro networks with a few thousand points each, about 5 or 6 nodes in each network, so nothing too heavy.
Devs please let me know if you want the scene & I will send via PM.
Solved by mspeer. Go to Solution.
Hey @arcon76 feel free to PM me your scene file and I'll take a look at what this issue is 🙂
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Sorry for delay, I can't send an attachment by PM it seems... attached to this message. Scrubbing in the timeline can eat a GB in under a minute. Can't work with MASH in this state.
Have tried flushing ram script and lowering undo que, no effect.
Hi!
I tested this with a fresh scene a cube and one single MASH Network.
All nodes i tested (except Random) showed this behavior with Maya 2017 update 4.
You just need a very high Number of Points settings like 5000 or more, then add a node, hit play.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Hi!
It does not matter if a problem is posted here in a user forum, it's important that this is send to Autodesk as a bug report and logged there, which is the case here. It also does not make sense to keep this thread alive as only a bugfix will help in this case. So don't worry, it has not been ignored.
