Maya 2015 SP6 EXT1: OBJ File Contains Faces Shared By Multiple Groups
Hi Folks,
At a loss on this one; obviously missing something simple - not sure what though.
Have a model of a house that contains *no* combined meshes.  I have grouped the various parts of the polymesh in the outliner as follows:
undefined
BUILDING01 is one of the buildings in a large scene.  What I'm doing at the moment is exporting the selection (i.e. BUILDING01) as an .OBJ - has to be this format.
As a test, I created a new scene and imported the .OBJ.  I get the following information message:
"Your OBJ file contains faces shared by multiple groups.  Maya cannot create multiple objects for this file.  A single mesh object will be created instead.  The OBJ group information will be captured in Maya sets."
Disabling Groups (and Point Groups) skips the information message but I end up with the same results ... a single polymesh in the Outliner.  I can use the Polygons > Mesh > Separate function but I lose the hierarchy and associated polymesh names.
Is there a proper method of exporting to .OBJ while preserving the Outline hierachy?
Advance thanks,
hgagne
Replies (8)
Have you tried ticking the option at the bottom of the panel 'Multiple Objects' and tick the 'Use legacy vertex ordering'?
Hi natcoll,
Appreciate the reply; the .OBJExport panel doesn't appear to have the "Legacy Vertex" option anymore ...
undefined
damaggio
Out of Maya, the best option is FBX...obj is terrible in Maya...maybe try that.
Hi damaggio,
Appreciate the reply; I have exported an .FBX version - tested in 3DS Max and a re-import in Maya.
Understanding that .OBJ is not ideal, would appreciate some confirmation that .OBJ is just *not* capable of supporting groups ... seems like .OBJ is still accepted as one of the defacto output standards that a "good" mesh/scene should support.
Cheers,
damaggio
From my experience when I export OBJ, even as groups it comes out as one merged mesh....stick with the FBX whenever you can, I really don't know technically why it does not work as OBJ.
Much appreciated!
I was able to export the .OBJ via 3DS Max 2015 ... at least the meshes are named according to their original "topmost" group names as opposed to PolySurface with a bunch of SETS.
Separating the meshes creates "PolySurface" entries but at least it localised - i.e. not Outliner > PolySurface > PolySurface.
Cheers,
santd
Thank you for posting to the Area Forums.
From testing in Maya it doesn't seem to be quite possible with the OBJ format. I do see that Maya creates sets with different face selections depending on the group they existed in, but it is difficult to translate that into the hierarchy that actually existed. I usually stick with OBJ when only exporting the model and no other information. If I am trying to get other information such as hierarchy, animation, rig, etc. I stick to FBX.
Hope you are able to workaround this issue somehow, but I am not really finding a way with OBJ.
Cheers,
David Santos
Hi santd,
Appreciate the reply.
As you can see from the original post screen capture; the model meshes have been organized into group.  I have separate groups (not displayed) for lights, cameras, etc. at the Outliner Top Level.
I exported to .OBJ by selecting the "Building" group assuming that when I choose File > Export Selection, the exporter would export the group name and meshes.  Obviously, that's not working as expected.
As per my previous post(s) in this thread, I ended up having to use the Maya .FBX exporter, importing the .FBX into 3DS Max 2015, and then use the 3DS Max OBJ exporter.
I guess the "take away" from this reply is that ADSK should look to build a "standardized" set of individual exporters (ex: OBJ, FBX, etc.) that function across their entire product lines.  Understanding that this may be an initial coordination effort, it would certainly go a *long way* into standardizing the user experience with native exporters - i.e. the behavior would be consistent regardless of products.
JMHO.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
