Show only
Search instead for
Are you sure? How do you know? If you are right, then is there any possibility for Autodesk to launch advanced modelling plugin for older versions? Another thing: In the case of Maya 2013, both versions of 64 and 32 bits were released at the same time or the 32 after the launch of 64? I have heard on other forums that 3D Studio Max 2014 is also 64 bits only. Can this make a difference?
32bit systems are only using 4gig ram.. and thats causeing a lot of problems and you have to develop features twice in some cases... it makes no sence to support 32bit system with maya mudobx or max...
if you need the modeling tools... use NEX from digital raster its the same...
