10:02 AM
Hi @Anonymous
It looks like you may have imported the image a different way then you're supposed to for image planes.
It looks like you're trying to use the front of a head as reference so to do this, navigate to the 'Front View' then go to View->Image Plane-> Import Image.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
no help but i found that image selection through cursor is in maya 2016 not in 2013 versions i select image plane through cameras side - top front cameras
Hi @Anonymous
Does that solve your issue or is there anything else I can help you with?
All the best,
Sean Heasley
Yes Thanks But Cannot Rotate Image Plane
Hi @Anonymous
You can't rotate image planes, this is by design.
If you want the image on a plane you can rotate, you would need to create a plane and assign the image to it as a texture under the Material Attributes.
Let me know if you need any more assistance or if this solves your issue!
All the best,
Sean Heasley
Hi @Anonymous
All the best,
Sean Heasley
Creating a primitive plane and assigning textures worked for me thanks!!!
