Maya 2012 Batch Render Not Rendering
I have a file that I've been trying to put together a rough test render for and Batch Render is not cooperating. I've seen a bunch of threads along these lines, but none of the solutions seem to work out.
Currently I'm just trying to render 1 frame from each render layer with Batch to get the overall look. I can Batch Render the individual frames with Software Render, and I can render individual layers in the Render vView Window. But Batch Render with mental ray settings is not working. It says it starts to render, waits a few moments, and says Render Complete, but produces nothing. Console shows the following:
Starting "/Applications/Autodesk/maya2012/Maya.app/Contents/bin/maya"
mental ray for Maya 2012
mental ray: version 3.9.1.48, Dec 7 2011, revision 162457
File read in 2 seconds.
Result: /Users/thompirson/Desktop/In Progress/43542 - Animation/scenes/6x6Model_Optimized__1342.mb
initMPS with licenseOption 0
Stack trace:
4 libadlmint.dylib 0x0000000106293815 str_strip_whitespace + 53
5 libadlmint.dylib 0x0000000106298772 TStr::stripWhiteSpace() + 34
6 libadlmint.dylib 0x00000001062f9cc9 AdlmLoggable::dumpSystemInfo(AdlmLogger*) const + 425
7 libadlmint.dylib 0x00000001062fa20f AdlmErrorBase::dumpTechSupport(AdlmLogger*) const + 31
8 libadlmint.dylib 0x00000001062f995c AdlmLogger::log(AdlmLoggable*) + 172
9 libadlmint.dylib 0x0000000106157217 CAdlmIntSATSLicense::validateAndShowRegNag() + 1879
10 libadlmint.dylib 0x000000010615b0d5 CAdlmIntSATSLicense::checkoutLicense(adlmPRODKEY const*, adlmPRODKEY const*, adlmBOOLEAN, adlmLICENSEINFO*) + 4469
11 libadlmint.dylib 0x000000010616bcbc CAdlmIntSATSSessionHandle::checkoutLicense(void*, adlmPRODKEY const*, adlmPRODKEY const*, adlmBOOLEAN, adlmLICENSEINFO*) + 76
12 libadlmint.dylib 0x00000001061631b9 CAdlmIntLicenseMgr::checkoutLicense(void*, adlmPRODKEY const*, adlmPRODKEY const*, adlmBOOLEAN, adlmLICENSEINFO*) + 89
13 libadlmint.dylib 0x000000010613d0e8 impoflldadtleonys + 104
14 libFoundation.dylib 0x0000000100870689 madlm_product_request + 969
15 libFoundation.dylib 0x0000000100870eaa madlm_subfeature_request + 1530
16 libFoundation.dylib 0x000000010086c4bc kGrainTextureSimul + 300
17 Mayatomr.bundle 0x00000001197cfda7 uninitializePlugin(MObject) + 935
18 Mayatomr.bundle 0x00000001197d7742 initializePlugin(MObject) + 28242
19 Mayatomr.bundle 0x00000001197d579d initializePlugin(MObject) + 20141
20 libOpenMaya.dylib 0x0000000116a9cc19 THcommandObject::doIt(TargList&) + 137
21 libCommandEngine.dylib 0x0000000100b1882d TmetaCommand::doCommand(TargList&) + 93
22 libCommandEngine.dylib 0x0000000100b18ad7 Mel_Command_Dispatch(SphNode*) + 279
23 libCommandEngine.dylib 0x0000000100b64b69 f_function_entry_node + 1097
24 libCommandEngine.dylib 0x0000000100b3c129 node_exec + 89
25 libCommandEngine.dylib 0x0000000100b3c1ed sophia_call_executable + 109
26 libCommandEngine.dylib 0x0000000100b6012c SophiaExecutable::evaluate(void*) + 124
27 libCommandEngine.dylib 0x0000000100b1e855 TcommandEngine::executeCommand(SophiaExecutable*, void*) + 197
28 libExtensionLayer.dylib 0x0000000101316bc9 TelfEvalCmd::doCommand(TargList&) + 89
29 libCommandEngine.dylib 0x0000000100b18ad7 Mel_Command_Dispatch(SphNode*) + 279
30 libCommandEngine.dylib 0x0000000100b3c129 node_exec + 89
31 libCommandEngine.dylib 0x0000000100b650fb f_function_entry_node + 2523
32 libCommandEngine.dylib 0x0000000100b3c129 node_exec + 89
33 libCommandEngine.dylib 0x0000000100b650fb f_function_entry_node + 2523
Result: /Users/thompirson/Desktop/In Progress/43542 - Animation/scenes/6x6Model_Optimized__1342.ma
Fatal Error. Attempting to save in /var/folders/8n/yhkn2d0s66d89dwgq7_0z0380000gn/T/thompirson.20150102.1430.maWriting crash report in /var/folders/8n/yhkn2d0s66d89dwgq7_0z0380000gn/T/thompirson.20150102.1430.crash
QTMErrnoFromMachError: Mapping unrecognised Mach error in the errno range (0x11) to EINVAL (22).// Maya exited with status 1
2015-01-02 14:32:21.651 system_profiler[1779:131850] platformPluginDictionary: Can't get X86PlatformPlugin, return value 0
2015-01-02 14:32:21.652 system_profiler[1779:131850] platformPluginDictionary: Can't get X86PlatformPlugin, return value 0
Any ideas?
Also, I'm on a Mac and running Yosemite, in the past, I've deleted the User preferences, but since the office updated to Yosemite, there is no maya2012 user preferences folder to delete and reset the program. Any ideas where it might have gone to?
As a follow-up test, I've created a completely new file and new scene. Created a cube, moved it slightly and set two keys and it gives me the same error, which leads me to think the problem is in Maya/mental ray/batch render.
In the ongoing saga... I've
-figured out how to delete/reset preferences.
-imported scene data into clean file.
-run render diagnostics (comes back 0 errors)
-deleted history and optimized scene (sometimes fixes random issues, nope)
-double checked all file links
-finally resorted to uninstalling and reinstalling Maya 2012 and service pack updates. Console continutes to show:
Result: /Users/thompirson/Desktop/In Progress/43542 - Animation/scenes/6x6Model__2573.ma
Fatal Error. Attempting to save in /var/folders/8n/yhkn2d0s66d89dwgq7_0z0380000gn/T/thompirson.20150102.1723.maWriting crash report in /var/folders/8n/yhkn2d0s66d89dwgq7_0z0380000gn/T/thompirson.20150102.1723.crash
2015-01-02 17:25:13.205 system_profiler[2760:112776] platformPluginDictionary: Can't get X86PlatformPlugin, return value 0
2015-01-02 17:25:13.207 system_profiler[2760:112776] platformPluginDictionary: Can't get X86PlatformPlugin, return value 0
A bit more information, I brought the file home with me to test on a machine with the same Maya setup, but without Yosemite and it worked just fine. So the problem is either specific to Yosemite or my work machine...
Hi  Samohtep
Did you find a fix to this?
I have exactly the same issue with my new os El Capitan
Any advice appreciated
Neil
