Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Material order does not match between this model and its parent
1 REPLY 1
195 Views, 1 Reply
i work with cgtrader and my maya LOD0 and LOD1 file with 2 material had done. bt LOD2,LOD3 and LOD4 is showing error that Material order does not match from parent model. i can't find any solution for it. plz give a solution for it.M1-sofa42,M2-woodBlackM1-sofa42,M2-woodBlack
1 REPLY 1
patrick.schock
Hello @Anonymous,
thanks for posting this question. Can you please explain how you are creating the LOD's? In case you are creating the LOD's as described from these articles, there should be no issues with material assignment:
Generate LOD meshes
LOD Tutorial
If you are using a special workflow to create the LOD's you can send me a screencast in this post or in a PM to better understand the procedure.
Thanks and best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
