Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Mash Instancer Problem
1 REPLY 1
SteamFX
199 Views, 1 Reply
Hey there,
I'm currently creating an Environment Scene in Maya and Vray.
I need to create a large grass field for that, so I thought the Mash Instancer is the perfect solution, since the Bifrost one doesn't work with Vray. When im trying to set it up, all my Instances flying random over my Mash. All the Pivots are set to center.
Would be great if someone could help with that.
Thanks for the time,
1 REPLY 1
sepu6
in reply to: SteamFX
"since the Bifrost one doesn't work with Vray"
It does if you use USD it renders extremely fast directly in the graph.
Another option is to do all the scattering inside BF and then save it as an ABC and load the alembic through the Vray procedural.
About Mash, did you change the working units from the defaults?  if so Mash doesn't like that.
If that isn't the case, provide the scene so is easy to help.
