Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
MASH ID messing UVs
3 REPLIES 3
935 Views, 3 Replies
MASH ID messing UVs
Hello all,
So I'm animating objects using MASH. However when I use the ID node to get mash to insert random objects into the network it completely wrecks the uvs.... If I use the cycle option on the ID node then I get what I would expect, but random or linear distribution causes the issue. I've deleted the history on all the objects I'm distributing.
Anyone have any ideas?
3 REPLIES 3
jhanzelka
Ran unto to this same problem, seems to be caused by mesh in the repro with conflicting UV set names (eg: 'UVmap' vs 'map1').  Changing these to all have the same UVset name fixed the issue.
jordan.giboney
Hi @Anonymous
Thanks for posting! Did you have a chance to try out @jhanzelka 's suggestion? Any luck?
If you have found a solution, we would love to hear about it and mark this thread as solved. Clicking the "Accept Solution" button helps other forum members find the answer faster.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
EderSouzadesigner
I am having the same problem. only ID node mess with the UV's 😕
