Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
MASH distribution on mesh with offset
16 REPLIES 16
Message 1 of 17
saschareimold
2002 Views, 16 Replies
Hello there,
I have a small problem, but it is a problem. I want to create a grass carpet using MASH and PaintFX. When I distribute the grass on a floor_mesh there is a slight offset (as you can see on the pic) and I have no clue where this comes from.
Maybe someone knows where this comes from?!
Sascha
16 REPLIES 16
Message 2 of 17
mspeer
in reply to: saschareimold
Hi!
Please upload the scene-file.
(A scene can't be checked without the scene and there are too many reasons possible for this result.)
Message 3 of 17
saschareimold
in reply to: mspeer
Of course. Attached a scene file.
Can't upload a file here. Don't know why, but here is a link:
https://www.dropbox.com/s/sjaskgn3lehgwod/MASH_offset.mb?dl=0
Thank you.
Message 4 of 17
mspeer
Hi!
The original mesh "grassBent1Main" is not at scene origin.
Just move this mesh to scene center.
Message 5 of 17
saschareimold
in reply to: mspeer
Thank you!!!
Message 6 of 17
selma.pease
I have the same problem but my object is freeze transfo, can this still be the problem?
Message 7 of 17
in reply to: mspeer
I have the same problem here, but your hint did not solve the problem.
Zero transformations, no history, just plain, clean geometry. Wherever I place it, the Mash points are not distributet on the surface.
And yes, I did connect the mesh into the input mesh.
It is annoying.
Message 8 of 17
mspeer
Hi!
Please provide a scene-file.
Message 9 of 17
in reply to: mspeer
Hi and thanks for your help in advance.
Here we go.
I cannot make out where the problem ist.
Message 10 of 17
selma.pease
in reply to: mspeer
That worked, thanls alot! 😞
Message 11 of 17
here is the scene.
Message 12 of 17
mspeer
Hi!
Your source meshes are also clearly offset, use Bake Pivot to correct this.
Message 13 of 17
in reply to: mspeer
Hi mspeer,
I can not see what you mean. My source
and my target meshes as well have no offset at all (freeze transormation - maybe thats what you meant by bake pivot).
Not even one mesh in the scene has transformation/rotation/scale values.
No history, no nothing.
Do I misunderstand something?
Message 14 of 17
mspeer
Hi!
Move the object to the center of the scene and then check again the values.
This is not the center of the scene, the mesh is offset from the center and this offset will be applied to your objects in MASH too.
Also Bake Pivot is not the same as Freeze Transformation, please check the Maya online help.
Message 15 of 17
in reply to: mspeer
Hi there,
so center of the scene, new created plane.
No offset at all but still the same problem.
I am lost here.
Message 16 of 17
mspeer
Hi!
Check your object "pasted__leaf02", it shows 0 0 0 for translate, but it's clearly not at the center of the scene.
This is a huge offset.
Message 17 of 17
kternask
If you've centered and froze transformations and all of that and it still doesn't work make sure you are in default cm units. I had this issue and changed it back to cm from inches and it worked perfect.
